11-26-2015, 08:27 AM | #1 |
Ye ritely?
Rep 26
BMW Retrofit in N.I?
Hi guys, im after a contact who retrofits upgrades for my F30 here in Northern Ireland, teaston on the forum gave me the website of Campbell Fox, but there is no contact number or email on the site. Any help is much appreciated.
2008 320d MSport -- 2012 318d Sport
11-26-2015, 10:41 AM | #4 |
Rep 32,881
I think it's fairly plug and play if converting from your non nav system. There's a bit of coding but all you'd need for that is a sub £20 cable and the programs and guides which I can send you.
11-26-2015, 10:45 AM | #5 |
Rep 319
I'm in NI, and hadn't heard of Campbell Fox?
Didn't believe you that they couldn't have not put contact info on their website, but they haven't!!? Madness! If you get anywhere with this I'd be very interested!
BMW F12 M-Sport|Pro-Nav|Space Grey|20" 373M|
11-26-2015, 12:37 PM | #6 | |
Ye ritely?
Rep 26
11-26-2015, 12:41 PM | #7 | |
Ye ritely?
Rep 26
11-26-2015, 01:59 PM | #9 |
Rep 32,881
steddyman did the retrofit from the no nav system like yours, read from post #13 in this thread:
http://f30.bimmerpost.com/forums/sho...light=Retrofit |
11-26-2015, 01:59 PM | #10 |
Rep 1,894
I'm assuming you don't have the business nav and you have just the basic non-nav 6.5" screen and HU_ENTRY.
You will need: - 8.8" LCD - Monitor Cable (Pink to Burgundy), the HU_ENTRY (Burgundy to Burgundy does not work/fit) http://www.ebay.co.uk/itm/BMW-Naviga...IAAOSw1vlUtWzR - IDrive Controller - NBT Unit (Don't get the NBT-EVO, if you want to generate your own FSC codes) - Emulator (to enable NAV) http://www.ebay.co.uk/itm/Plug-and-p...wAAOxyHIlTYVyh - Coding (Add 609, 6NS and 6NR (if you have Apps) to your VO) - GPS Antenna, most sellers normally will give you this. |
11-26-2015, 02:05 PM | #11 | |
Rep 32,881
11-26-2015, 02:13 PM | #12 |
Rep 32,881
11-26-2015, 03:04 PM | #16 |
Rep 32,881
In all seriousness it isn't actually quite as plug and play as I thought. It is possible that you just plug it in and most features will work, but if for example the car the pro nav came out of had HK sound system, then you will get no sound in your car until it's coded for your sound system. So little things like that could make it difficult.
11-26-2015, 03:05 PM | #17 |
Ye ritely?
Rep 26
Hmmm, i would really like to find someone who could get this all done, wish i had of understood all this sooner.
11-26-2015, 03:08 PM | #18 | |
Rep 32,881
Or find a decent auto electricians near you and ask if they can help. |
11-26-2015, 03:22 PM | #21 | |
Rep 1,894
Seriously, when you plug in the NBT and emulator about 90% will work, even without coding. You'll have to add the 609 and 6NS to your FA, then VO code the NBT. If the NBT is missing time/date etc etc on startup, then you'll need to VO code the KOMBI. Your biggest issue will be the USB as you'll need to shave the connector and rotate it 180 degrees or buy a new cable if you want preserve the existing connection. |
11-26-2015, 03:22 PM | #22 | |
Rep 32,881
Some you can definitely do are: digital speedo, auto start stops remembers if set to on or off, disable seat belt reminder, turn off radio when drivers door opened, set different lights to come on when you unlock the car (welcome lights) |
