11-18-2015, 04:10 AM | #1 |
Rep 809
Is it possible...
To start your engine, take your key out and lock the car? Or even leave key in car and lock with spare key?
This would help on icy mornings to leave the engine/heater running to clear the glass. I've done a search but could only find information about being able to drive the car without the key, without being able to restart. Thanks chaps. |
11-18-2015, 04:12 AM | #2 |
Rep 2,468
Drives: F21 M135i LCI
I think you can, I am sure I read someone here forgot to stop the engine, got out and locked the car and walked away! When he got back to the car the lights were on, engine running! To his amusement!
Current: F21 M135i Mineral Grey and few options
Previous: F30 320i XDrive, E85 2.5i, E21 323i |
11-18-2015, 04:18 AM | #3 | |
Rep 8,501
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
11-18-2015, 04:20 AM | #4 |
Rep 1,799
Me too.
I've also done the park car, lock it , walk away and return to find the engine still running
U06 230e Active Tourer |
Previous : 2019 F31 340i : 2017 F31 335D M-Sport |
11-18-2015, 04:21 AM | #5 | |
Rep 3,983
San Marino Blue M3 Competition Package with Carbon tat, ACS RS suspension, uprated brakes, 'modded' exhaust and a weeny bit more power courtesy of JF Automotive; M235i Convertible with ACS Sports Suspension; Disco 5 HSE Lux
11-18-2015, 04:21 AM | #6 |
Rep 3,216
Yes, you can.
Do however be aware that if anyone breaks the glass, they're away with your car. And your insurance could well (if the car as found and ECU interrogated) invalidate your insurance. Furthermore, leaving a car running while unattended on a public highway is a criminal offence - however if it is on a private drive you are not committing an offence. I must admit, I think that the engines in modern cars are so thermally efficient that you'll only be circulating cold air. My car takes 5-6 miles of driving before the needle even starts to move off 'cold'. |
11-18-2015, 04:24 AM | #8 |
Rep 1,799
Is that you NTG ?
11-18-2015, 04:28 AM | #9 | |
Rep 438
11-18-2015, 04:28 AM | #10 | ||||
Rep 809
You do make a good point re circulating cold air, the reason I'd want to do it is to clear the glass of ice, sounds like it might not even work I'm from Manchester and comfortable with my sexuality, not a confused Greek/French man? |
11-18-2015, 04:29 AM | #11 | |
Rep 738
X3 M40i Carbon Black
11-18-2015, 04:31 AM | #12 |
Rep 964
Hello Mr Obvious :
F36 435i M Sport
11-18-2015, 04:32 AM | #13 | |
Rep 738
I guess you northern laydees have your hair dryers and straighteners to keep you warm oh, I mean French laydees .......
11-18-2015, 04:33 AM | #14 |
Rep 6,945
This is the electric heater, rather than engine warmth. In freezing conditions, I can feel the warmth from the heating within about 90 seconds, and by 3-4 minutes the car is warming up.
11-18-2015, 04:42 AM | #16 | |
Rep 738
Can that be operated via the BMW App? I know you can activate the fans, but thought it would just blow cold??
11-18-2015, 04:44 AM | #17 |
Rep 809
11-18-2015, 04:45 AM | #18 |
Rep 6,945
I don't think it can be operated via the app as it would cause significant battery drain. I didn't know about the heater until HighlandPete mentioned it some time ago, but it makes sense, as in cold conditions, the air gets warm long before the engine does .
11-18-2015, 04:50 AM | #19 |
Rep 145
I thought the car cannot be driven without the key fob being in the car. So if you start the car on your driveway and then run back inside the house with the key fob ... doesn't the car warn you ?? Can it still be driven away at that point ?
11-18-2015, 04:50 AM | #20 |
Rep 175
11-18-2015, 04:53 AM | #21 | |
Rep 809
Apparently once the engine has stopped you cannot start it again (some mentioned it can be started again within 10 seconds of turning off). Would be interesting if you've got stop/start switched on lol Where's the "get your coat" smiley? |
11-18-2015, 05:45 AM | #22 |
Rep 438
