2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Tracking / Autocrossing Schroth Quick Fit Pro fit m235?
      11-07-2015, 08:20 PM   #1
Foozed
Drives: 2012 e92 M3
Does the model they sell for the 1 series fit in the m235?
Is there an alternative for a 4pt harness that uses the stock belt anchor points?
I used these in an e92 m3 at the track and found it very helpful over struggling to keep my place in the seats and would like to try these in my new m235 track toy before investing in seats/bar/6pt.
      11-12-2015, 09:53 PM   #2
Pparana
Drives: 2015 m235i
I use one, needed to change the rear seatbelt receiver, maybe the one for e93 would fit without modification
      11-25-2015, 06:27 AM   #3
Foozed
Drives: 2012 e92 M3
Ok will give it a try. Thanks.
      01-06-2016, 08:04 AM   #4
Straight6Driver
Drives: F30 335i
Any updates to this?
      01-26-2016, 09:45 AM   #5
Dylan86
Dylan86's Avatar
Drives: F15d msport, F22 m235i
x2
      02-23-2016, 09:12 PM   #6
Pparana
Drives: 2015 m235i
sorry guys, I will post some pics in a week or so on what I did, its pretty straight forward.
      02-23-2016, 11:54 PM   #7
rwalker
Drives: the wheels off
will be a big boon to the community, thanks!
HPDEs require that we have equivalent passenger restraint; we'd benefit from your opinion, advise on using Schroth Quick Fit Pro on that side too...
      03-17-2016, 01:28 PM   #8
rwalker
update?
      03-17-2016, 05:08 PM   #9
Pparana
Drives: 2015 m235i
Originally Posted by rwalker View Post
update?
never, just kidding, car is up on lift at work, will try to get some photos tomm. when I lower it down.
      04-05-2016, 10:18 AM   #10
Drifa
Drifa's Avatar
Drives: Mineral Grey m235i
update
Any word on this?
I'm quite serious about picking up a set for my m235i and curious if they work
~Danielle
1995 Porsche 911
2015 volvo xc-60 t6 awd
      04-15-2016, 12:55 PM   #11
Pparana
Drives: 2015 m235i
sorry for the delay,
here is what I did. has been almost a year, so some information may be foggy.
I used a e46 harness,
install per directions.
Change the seat belt receiver in rear to e46 type.
Change the male part on the harness to a 2er type blade (type B I believe), this can be undone on the harness.
note rear seat belt will not be usable.
Newer body style harness may be plug and play.
Ignore typo below, e36, should be e46.
      05-22-2016, 08:02 PM   #12
MilehighM3
MilehighM3's Avatar
Drives: Harrop E90 M3
2009 E90 M3  [6.50]
An E82 quick fit harness will plug right in for anyone that would like to get them. FYI
      05-22-2016, 08:50 PM   #13
Mywifes335
Mywifes335's Avatar
Drives: 2014 FBO M235i
Are there any ASM harness systems available like this without necessitating a roll bar?
Originally Posted by Axius View Post
Why the sad face, I fucking love sausage.
      05-22-2016, 09:39 PM   #14
rwalker
Thanks for posting this. How did you confirm?
rwalker@rwalker.com (I really dislike Private Messaging)
      05-22-2016, 10:49 PM   #15
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
Why no harness bar?
many tell you not to use these types of harnesses do to the angle and the compression on the spine and neck in case of an accident.
I'm looking into finding a harness bar. A cage will run 5-10k alone.
www.nybmwcca.org
Current Cars:
1995 M3 Coupe Manual Alpine White
1997 M3 Sedan Auto Cosmo Black Metallic
2018 x3 m40 Auto Grey Metallic
      05-22-2016, 10:53 PM   #16
Mywifes335
Mywifes335's Avatar
Originally Posted by bryan_f22 View Post
Why no harness bar?
I figure it would be crazy pricey and impractical. But if the angle safety is true, shit, harness bar it is.
Where did you see this info?
      05-22-2016, 10:57 PM   #17
bryan_G01
bryan_G01's Avatar
1165
BRracing has one for the 135.. im sure it can be fitted for a m235.
Its $1200.00.
www.nybmwcca.org
Current Cars:
      05-22-2016, 11:07 PM   #18
bryan_G01
bryan_G01's Avatar
1165
The safety of it gets brought up in every track classroom i've ever been in.
At the end of the day, the safest you can be is in a racing seat, with 6-point harness and a full, custom roll cage with HAANs device. Everything else will have a weak point.
But a fully caged car on the street provides huge risk as ur not wearing a helmet and a roll cage will hurt your head.
A harness bar or the bolt in's will not help you in the event of a roll over. Thats why you get the full cage.
Safety is very debatable. It comes down to your comfort level.
A race prep car will cost 30k easy to be performed.
www.nybmwcca.org
Current Cars:
      05-22-2016, 11:44 PM   #19
MilehighM3
MilehighM3's Avatar
2009 E90 M3  [6.50]
I took a set from a friends 1M and installed them in another friends M2. The E36/E46 have a different buckle and they're not compatible. I learned this going from my E36 to my E82. I saw this post and thought I would add the information for others to use. Apparently Schroth has yet to complete their F2/3x testing, so they haven't released the belts for sale on these models.
Regarding safety, the safety of a 4 point is not only the angle, but also the head protection. It is highly recommended to use a HANS device with any 4, 5 or 6 point. When your shoulders are secured in a 4+ point configuration, this leaves your head and neck vulnerable in the event of an impact. I would recommend a belt with ASM such as the Profi2 ASM over the quick fit, but that's just me. Harness bars are great when you want belt systems installed, but only in terms of belt angles in relation the quick fits and in regards to passenger safety in an impact. For a street car, 4 points properly installed with ASM tech would be my belt of choice.
      05-27-2016, 08:40 AM   #20
Pparana
Drives: 2015 m235i
This thread is a bit misinformed in the quick fit belts, there designed for no bar. They actually are the only harness that is dot approved.
If you wear a hans and use a stock seat, quick fit is a safe choice over 3 point stock belts.
Here is a video:
You absolutely do not want to run a harness bar in a car that is a street car. Unless you plan on installing race seats and wearing a helmet all day. Dot banned factory harnesses, roll bars in street cars, that's why they are not availible in 911s any more from the factory.
      07-29-2016, 05:58 PM   #21
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
Why no harness bar?
ask if they will be doing a 2 series bar?
http://www.bkauto.com/category_s/85.htm
      07-29-2016, 08:11 PM   #22
bryan_G01
bryan_G01's Avatar
1165
http://simpsonraceproducts.com/hybri...lt-compatible/
www.nybmwcca.org
Current Cars:
2addicts
