2Addicts
2Addicts
2Addicts | BMW 2-Series forum Classifieds Members Classifieds Suspension / Brakes / Chassis / Spacers New Ground Control Camber Plates for M235i/F22/F30
      11-05-2015, 04:18 PM   #1
zipphreak
Drives: m235xi
USD 525.00
✓ Will Ship
These are brand new and never mounted. They are the updated version 2 for the F22 (m235i), they also fit the F30 chassis.
Shipping is estimated at $20, please send zip for exact quote.
These plates feature over 30mm of total camber adjustment with the ability to make corrective caster changes to equalize side-to-side caster in the stock position.
Other features include replaceable waterproof German axial load bearings, and isolated aerospace grade strut bearings for long life, less deflection, on stock sized or aftermarket springs.
Our camber plates are also engraved with the Ground Control logo and markings which can be used to locate the plate in the stock position for easy, fast adjustments.
Camber is separately adjustable by the center slider, without removing any components from the car. The priority of this design is to allow fast, easy, and repeatable adjustment from street to track and back.
All components are anodized or zinc plated for corrosion resistance.
We also offer our lifetime guaranty! (Bearings not included)
• A clean sheet design for street cars, not an adapted spherical race plate.
• Waterproof, German-made, axial load steering bearings.
• Allows for up to 30mm total camber adjustment.
• Unique slot design allows for caster correction.
• Aerospace grade strut spherical bearings.
• All components plated or anodized for corrosion resistance.
• Zinc plated mounting bracket for ease of install and adjustment.
• Reuses stock rubber spring pad for noise isolation.
OEM BMW upper spring isolator must be transfered onto camber plates when using factory diameter springs.
Torque camber plate mounting nuts to 18ft/lbs using properly calibrated torque wrench. DO NOT USE PNEUMATIC TOOLS
All Ground Control products carry a lifetime guarantee against defects when installed and maintained correctly. We strongly recommend that all of our products be installed by a competent, qualified mechanic.
      01-27-2016, 11:29 PM   #2
varun
Drives: '14 550i M-sport
Hello, are these M235i camber plates still available? If so please respond to my PM, Thanks!
      01-30-2016, 09:51 AM   #3
zipphreak
Drives: m235xi
All PM's responded to.
      02-04-2016, 11:42 PM   #4
Siver 335i
Drives: 2007 335i
Camber plates
Are these for factory springs
Attachment 1313278
Attachment 1315736
Attachment 1315737
Attachment 1315738
Attachment 1315739
Attachment 1315740
      02-05-2016, 11:12 AM   #5
zipphreak
Drives: m235xi
Yup factory springs, OE height.
      04-19-2016, 11:25 AM   #6
zipphreak
Drives: m235xi
Bump still for sale. I need some money for a new FMIC. These have never been mounted, brand new GC camber plates for F22/F30 chassis. Let me know if you have any questions. I can ship ASAP.
      05-25-2016, 04:38 PM   #7
beemerman1984
Drives: Hummer H1
PM me your best price. I am interested.
www.vixere.co #theylived
2addicts
