10-28-2015, 12:49 PM | #1 |
Rep 5
Winter tires
I have a 2015 328 xdrive msport:
I need to install winter tires. I have the 19 inches wheels staggered I cant find the run flat tires here (in QC) 225 40 19 255 35 19 Does anyone found some ? winter runflat Thanks |
10-28-2015, 12:56 PM | #2 |
Rep 851
Dont put winter runflats on.... they are terrible. Just buy normal winter tires on. or buy seperate rims and get a CAA membership. Will save you money in the long run.
10-28-2015, 01:03 PM | #3 |
Rep 2,639
Downgrade your wheel size if possible. i live in quebec as well, and have a set of oem 17's with brand new nonrft performance winters for sale if you want to spend less. Blizzaks lm-32
10-30-2015, 09:18 AM | #4 |
Rep 1,447
Do you have the M-Sport brakes? If yes you can go down to 18" if no you can go down to 16". Runflat winter tires are rare so I went with Nokkian Hakka 8 with stud 225/50R/17 RFT. There are other option with Nokkian for 18".
10-30-2015, 11:32 PM | #6 | |
Rep 1,369
Runflats? I get the concept but ultimately if it gets damaged you still need to replace it and I don't believe RFT have any better sidewall protection than GFTs. In fact, every tire I've ever lost has been due to sidewall damage. Enjoying the Michelin X-Ice3 since last winter. Very happy with those. |
10-31-2015, 03:23 AM | #7 | |
Rep 2,639
11-07-2015, 09:51 PM | #9 |
Rep 749
Drives: 2016 528i Executive Edition
Do you have msport brakes? If so you will likely need 19s in most aftermarket rims. Most aftermarket 18s do not clear the m sport brakes. Only some do. All oem bmw 18" wheels will clear them though.
*I'm assuming the m sport brakes on the 328 are the same as the 335 As for tires forget the runflats. They are horrible. |
