Microfilter service
02-22-2008, 04:14 PM | #2 |
Rep 2,353
Drives: 2009 Z4 sDrive 23i
Is this the same as the pollen filter?
When I got the Z4 serviced they initially didn't have the filter in stock. They asked me to take it back in, and it took about 10 mins to fit... I just waited for it. I think it was located somewhere down at the passenger footwell area.
E89 Z4 sDrive 23i... for the more discerning driver
02-22-2008, 04:16 PM | #3 |
Rep 2,426
Drives: E93 335i M-sport
if it's the filter that filters cabin air, that takes like 2 minutes to change. Only 6 8mm fasteners to remove
SJ |
02-22-2008, 06:08 PM | #6 |
Rep 1,134
Drives: BMW G20 330e M Sport MY20
Mines due in 3k.
stealer told me its 30 mins in garage tops
20 BMW G20 330e M Sport Portimão Blue/Cognac, Driver Pro, Tech,M+ lumbar, storage packs
Long gone -15 Peugeot 308 2.0HDi GT AUTO Magnetic Blue, 10 BMW F10 520D SE Xirallic Imperial blue/Cinnamon Brown, 06 E90 320si - Le Mans Blue - Totally standard specification (Scrapped RIP 12/08/2010), 00 Peugeot 306 2.0 SE Cabriolet, 94 Rover 214 SEi, 91 Fiat Uno 60S Mk2 |
02-23-2008, 04:38 AM | #7 | |
Rep 270
I would just wait with the car.Pointless leaving it.
Le Mans blue/ black leather with Aluminum trim/ privacy glass/ xenon's/ black line rear lights/ OEM 18inch M Sport wheel upgrade/ PDC/ blue tooth/ Hi-Fi speaker system/ heated front seats/ storage pack/ auto lights+wipers/ green sun strip/ OEM boot spoiler/ external mirror package. |
02-23-2008, 07:08 AM | #9 |
45
Rep 408
To reset a brake pad warning, all you have to do is replace a worn sensor and or pads and then turn the ignition off and then back on and leave it for upto 1 minute.
The system works by the sensor comming into contact with the brake discs when they wear and creates an open circuit. By checking or simply removing the sensor if its defective, leaving the ign on will allow it to reset. |
02-23-2008, 07:37 AM | #11 |
The Tarmac Terrorist
944
Rep 29,345
Drives: 997.2 GT3
at what mileage is this thing due?
997.2 GT3
02-23-2008, 08:29 AM | #12 |
Rep 270
Mine was done at 30,000.
02-23-2008, 10:34 AM | #13 |
45
Rep 408
You can change them at any time, for the cost I allways put a new one in periodically. They change to a dark grey colour and as all the air that goes into the passenger cabin passes through it and we breath it in, for the cost, I change them anyway when I sense the slightly musty smell... But thats just me.
02-23-2008, 10:43 AM | #15 |
45
Rep 408
02-25-2008, 08:35 AM | #19 |
944
Rep 29,345
Drives: 997.2 GT3
at what service is the mirco filer due? (mileage also?)
997.2 GT3
02-25-2008, 03:37 PM | #20 |
Rep 1,134
Depends where you drive
If you drive in a hot desert - then it'll be round quick. (Just because there is a hosepipe ban in summer in Essex it doesn't count) Check yours through your stalk or idrive (delete as applicable). Mine is going to be due at 43k - but as i've seen it may not really of relevance to any non si cars. As the sparks were changed at 25k ish.
07-04-2008, 09:22 AM | #21 | |
Rep 2
I've got the rear brakepad replace warning also. I've tried to reset the warning light but that doesn't work so I reckon the pads are actually worn (there's 50K miles on the car, I bought it with 40K miles). I'm gonna buy the pads and fit them tomorrow if necessary. Do you know does the sensor come with the pads or will it be a separate item? I'm assuming if the pads are OEM that the sensor will be separate.. Thanks in advance. |
07-04-2008, 09:55 AM | #22 | |
45
Rep 408
