E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > NEED HELP! P0015 (Vanos? Cam Position Sensor?)
      10-13-2015, 11:27 AM   #1
JeffakaLucas
Drives: 3351
Car: 2007 335I (2 door, non nav, non i-drive)
Miles: 134,000
Mods: Vishnu proceed and vishnu intakes
Recent Work Done:
New starter, Spark plugs, belt, new air filters, new front main seal, new water pump, new pulley, new tensioner, new battery, coolant flush.
Problem: P0015: Camshaft Position, Act B - bank 1, timing over retard
A little back story. I changed my spark plugs with OEM spark plugs to rid myself of a misfire under WOT. Upon completion, I started getting intermittent P0015 codes and limp mode.
One day, driving to work, my car stalled and then wouldn't start. I had it towed home and found that somehow in the middle of vanos problems my starter took a dump. So I replaced my starter and the car now starts fine.
So, at this point, I've replaced both the exhaust vanos solenoid and the exhaust cam position sensor. I've tried swapping each to see if the codes changes to P0014 with no dice.
My biggest problem is, my car sounds TERRIBLE right now. It sounds like it's knocking or having valve tap or something. When I turn the car off this awful knock/sequel thing happens so I don't want to keep repeating that.
I've search all over the boards and pretty much anyone that throws P0014/P0015 replace the solenoid and the CPS and they are back in action. I haven't read of anyone having noises associated with these codes. My code reader only reads P0015.
Anyone have any suggestions on what could be wrong? Or what I should try next?
      10-14-2015, 05:02 PM   #2
JeffakaLucas
Drives: 3351
Sorry for posting in the wrong sub. Can someone delete this?
Tags
cam, p0014, p0015, position, vanos
e90post
