Give me some advice on repairs
08-26-2015, 12:42 AM | #1 |
Rep 2,349
I Want to replace just about anything that can go wrong
07 n54 120k miles People seem to misunderstand this post, im not worried about things i just want to replace things that may go out soon ish. I have some extra cash and i just like things to be nice. i do "not" want to buy a new car thanks for that advice though. If i wanted to buy a new car i wouldnt be on this forum :P Already replaced Suspension (Full coilover kit) Turbos all injectors spark plugs intake cover gasket valve cleaning intake walnut pcv valve both valve solenoids Clutch Parts on order next oil filter housing gasket oil pan gasket vacuum lines
07 E92
Jb4-G5 - Sport Exhaust - Titek BOV BBS Lm reps - AFE dual cone intake Last edited by 335iNavyGuy; 08-28-2015 at 10:22 PM.. |
08-26-2015, 04:36 AM | #2 |
Rep 18,772
Sounds like you are spending money on stuff that is not broken.
08-26-2015, 09:14 AM | #5 |
Rep 2,349
Replaced a lot of it out of suspicion and I would rather replace it now than be stuck on the road
07 E92
Jb4-G5 - Sport Exhaust - Titek BOV BBS Lm reps - AFE dual cone intake Last edited by 335iNavyGuy; 08-26-2015 at 09:38 AM.. |
08-26-2015, 01:51 PM | #7 |
Rep 2,349
Already done forgot to put that lol
07 E92
Jb4-G5 - Sport Exhaust - Titek BOV BBS Lm reps - AFE dual cone intake |
08-26-2015, 05:32 PM | #9 | |
Rep 18,772
Generally manufacturers tell you what parts should be replaced as preventative maintenance. Your parts list seems excessive for a 120,000 mile car. For instance the clutch; was it slipping at 120,000? Generally clutches give you plenty of notice prior to failure. How about the pan gasket; is it leaking so bad that it would cause engine failure? I've never seen a pan gasket leave someone on the side of the road unless they've neglected checking the oil level, which in an E90 is done for you and lets you know when the engine needs oil. Same for the OFHG. And vacuum lines. It would be smarter to have the car smoke tested to see if there are any real leaks in the vacuum system. Additionally a vacuum leak will generally show up as an emissions control device failure and throw a SES light. Another exapmle is the VANOS solenoids, I just clean and swap mine every 50,000 miles; they have 288,000 on them and I follow BMWs long OCI schedule. And if you think any of those new parts will increase the resale value, you’d be mistaken. The cost of replacing those parts will never be reflected in the value of the car on a dollar for dollar basis, so it’s a losing proposition for you and only a benefit for the prospective buyer.
08-26-2015, 06:17 PM | #10 |
Rep 1,735
It's called AAA
|instagram@underground6t9| |
08-27-2015, 12:02 AM | #12 |
Rep 715
As Efthreeoh said, what are the consequences of waiting?
The one thing I would replace is the water pump because when it goes, you are stuck on the side of the road. I was in a BMW indy shop today and a woman was picking up her car with 75K miles after being stuck. Most service advisors tell me water pumps usually last 75-125K miles. The thermostat is usually changed at the same time. |
08-27-2015, 01:56 PM | #13 |
Rep 2,349
Look everyone if you don't want to give ideas why post.. im not replacing the shit and throwing the old stuff away this is something I want to do to my car, I don't care if you think it's a good or a bad idea.. so why take the time to post 4 paragraphs I'm not even going to read.. if you have ideas for repairs or even upgrades on some parts that fail great if not go ahead and waste your time posting if it's not related to my question I won't even read it.
07 E92
08-27-2015, 03:27 PM | #14 | |
Rep 313
Drives: Like a hooligan
2016 F30 340i M Sport | 2009 E92 328i 6MT |
08-27-2015, 04:06 PM | #15 |
Rep 18,772
Hey, you asked for advice. I gave you some good advice. I'm an old dude with over a million miles of driving and have kept cars for as long as 18 years and over 280,000 miles. I've taken two BMWs past 250,000 miles, an Acura past 230,000 (all cars I bought new). I do almost all my own work DIY. You can replace every part on the entire car if you want to, but it's stupid. Fuel lines develop pinholes over time, keep a car long enough and you'll find that out.
If you want to waste money on a depreciating asset then by all means knock yourself out, but you don't need to be a dick about it...
08-27-2015, 04:09 PM | #16 |
Rep 18,772
Well he could replace the vibration damper every 50,000 in an effort to prevent crank failure.
08-27-2015, 04:30 PM | #17 |
I have to return some video tapes
362
Rep 4,712
Classic navyguy!
13 Carbon Black e70 X5M - 13 Black Sapphire e92 335i - 10 Le Mans Blue e92 335i - 09 Monaco Blue e92 328i xdrive - 07 Sparkling Graphite e92 328xi
08-27-2015, 04:40 PM | #18 |
Rep 1,602
Coils
Water Pump Thermostat Belt/Tensioner Engine mounts Low pressure fuel pump (upgrade while doing this) High pressure fuel pump Charge pipe (only go aftermarket on this) That should pretty much cover all the normal N54 issues on top of what you have done. If you intend to keep the car for a while I get it. These are not reliable cars and it makes sense to try to head off the common problems. |
08-27-2015, 09:52 PM | #19 | |
Rep 18,772
LOL
08-28-2015, 09:45 AM | #21 |
Rep 1,869
Suspension parts.
07 335xi (2007-2010)
08 Legacy Spec B (08-) 09 335i (2010-) 15 X5 xdrive 35i (2015-) 17 Forester XT (2016-) |
08-28-2015, 10:50 AM | #22 |
Rep 3,696
Thats probably his best bet... but it might have an unknown issue like bad airbags or some other fatal flaw that the first 1000 souls need to sacrifice themselves by so the rest of the world can say "Hey, maybe something is not right here..."
