07-20-2015, 11:03 PM | #1 |
Rep 709
Feeler FS: S65 block 94 mm bore
Really lacking the motivation to spend the money to rebuild this motor. Block is at Dinan right now and has been rough cut to 94 mm. Needs final hone depending on piston specs. 94 mm bore will give a displacement of 4.2L with stock crank and stock rods, or 4.6L with stroker crank and rods. This is for the bare block and base plate only. Nothing bolted to it is included. Cheapest dealer price I can find for a straight 92mm stock block is $5600 which includes pistons. Buyer will be responsible for supplying pistons for this block. At the point in time the buyer can specify the pistons and the finish work at Dinan can be done for those pistons. Don't have to sell it, so low ball offers will be ignored. |
07-21-2015, 12:10 PM | #3 |
Rep 709
Maybe. Blocks don't come up for sale often. If you are wanting to do a stroker build this block is ready to go. No waiting. A stock block is more from the dealer. If it doesn't sell I'll build it at some point in time...either a 4.2 or a 4.6.
