EXXEL Distributions
Go Back   BMW M3 and BMW M4 Forum > Classifieds > Sponsors Classifieds > Suspension / Brakes / Chassis / Spacers
      07-08-2015, 05:25 PM   #1
IND-Distribution
BimmerPost Supporting Vendor
IND-Distribution's Avatar
9575
Drives: G82 M4 / G87 M2
IND | Fall Line Motorsports F8x M3/M4 Rear Camber Shim Kit
When setting an M3 or M4 for high performance driving, properly setting the rear camber and toe will yield significant results. The rigidly mounted rear subframe and relatively low count of rubber bushings in the back of the car means that alignment changes translate very directly into the car’s behavior, and can be felt immediately when a change is made. The factory eccentric suspension bolts have a reasonable amount of adjustment range for a variety of ride heights and possible alignment settings, but are not a perfect solution.
The rigid camber shims will allow a technician to precisely set camber by choosing one of 5 shim offsets to install in the rear suspension. The shims can be used in either the normal orientation, or flipped, resulting in 9 different positions, divided into 1mm increments. This will give an exact camber setting, and ensures absolutely no change in alignment even in the harshest driving conditions.
Fall Line Motorsports F8x M3/M4 Rear Camber Shim Kit $165
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
The Fall Line Motorsports F8x M3/M4 Rear Camber Shim Kit may be viewed here in our online store: https://ind-distribution.com/product?sku=FLM-F8X-1BSHM
IND DISTRIBUTION | 866-963-4520 • INSTAGRAM • YOUTUBE • FACEBOOK • FLICKR
      10-15-2016, 12:46 PM   #2
ashmostro
Drives: 2020 M4cs | 2022 M550i
Would this shim kit allow for negative camber *beyond* the max factory adjustment available?
I have your adjustable rear toe arm but at the ride height of my eibach springs, I can only get - 1.8 degrees negative camber in the rear. I'd like more.
Thanks!
      10-17-2016, 12:23 PM   #3
IND-Distribution
9575
Thanks!
The shim kit does not enable adjustment beyond the normal range- the slot in the suspension allows the same amount of travel, so you're limited by what BMW has given you, in that respect.
The camber shim kit is intended to provide very rapid alignment changes, and also to maintain exactly consistent camber settings. Eccentric adjusters will slip under high cornering loads (especially with modified suspension and high performance tires), and the car's behavior can become very difficult to predict as a result. Using camber shims for adjustment eliminates that issue.
      10-18-2016, 11:37 PM   #4
ashmostro
Thank you!
      04-08-2017, 11:30 AM   #5
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
I have a question on these. I'm lowered on Eibachs and now of course have inner tire wear and am just looking for something that will allow me to get them back square like OEM. I'm not looking for aggressive tracks settings or anything like that. Will these do just that?
      04-10-2017, 04:40 PM   #6
IND-Distribution
9575
Yup! Exactly what they're for.
      04-12-2017, 09:53 AM   #7
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
Thank you!
      04-26-2017, 12:36 PM   #8
Nate@IND
Nate@IND's Avatar
2866
Install guide is now live on the new iND site
IND DISTRIBUTION | 866-963-4520 • FACEBOOK • INSTAGRAM • FLICKR
      09-02-2017, 06:26 PM   #9
M4 CSL
M4 CSL's Avatar
Australia
231
Drives: ///M4
I would like these. I am fine with the $165 USD price, but they want a further $250 USD to ship them.
///M4 | AKRA Evo & DP's | Brembo GT BBK | MSR CAI & CP's | MPSC2 |
Suspension : | KW CS 3-way | Dinan Toe Links | GC ARWJ & End links | IND Shims | SPL Control arms & End links | aFe Bars |
      09-07-2017, 06:30 PM   #10
IND-Distribution
9575
I'll be more than happy to provide a custom shipping quote for you!
PM sent
M4 CSL231.00
      09-07-2017, 10:27 PM   #11
M4 CSL
M4 CSL's Avatar
Australia
231
Drives: ///M4
PM sent
Thanks CAT, I ordered them online. But you will need to add the price you quoted me for shipping. Thanks.
      09-08-2017, 11:28 AM   #12
IND-Distribution
9575
Email sent, thank you!
f80post
