2010 2011 BMW 5 Series Forum F10 Please rank OEM suspension setups (Msport, Xdrive, sport, GT) to assist new F10 buyer |
06-20-2015, 06:42 PM | #1 |
BMW Nut
50
Rep 452
So back in the day I was a 3 series and M3 owner. 3 kids have forced me to go with a bigger car (to supplement my E70 X5, that my wife will start driving), and there are so many setup options I'm really confused.
I've been looking at 550i and 535i, with and without Xdrive. I know with the 3 series the Xdrive, whether they had sport option or not, always had a softer suspension setup. Is that true for the 5 series as well? So, could someone demystify this for me? How do they all rank in terms of firmness? The options I'm considering are GT (non-xdrive), M-sport (non-Xdrive), M-sport (Xdrive). The other thing I'm confused about is dynamic and adaptive drive. I've looked these up, and the only thing I can determine is that dynamic drive is like an adjustable damper setting, but adaptive drive is adjustable sway control as well. Then again, it seems like the adaptive drive option disappeared for the 2012 MY. It's enough to make your head spin. Bottom line, I want the sportiest setup I can get, preferably with M-sport option, but would love to get the Xdrive as well as long as it doesn't come at the cost of handling. Thanks for any and all assistance.
12 X5 xDrive35i | Platinum Gray | Oyster | Burl Walnut | Premium | Convenience | 3rd Row | Apps
13 Audi S4 | Misano Red | Black 04 S2000 | Berlina Black | Black |
06-20-2015, 07:43 PM | #2 |
Rep 2,323
Sounds like you like a nice handling car. If you are buying a RWD, get the MSport, it will come with the 704 sport suspension, its a fixed sport tuned suspension. The DHP option has adjustable shocks and sway bars, some people get the DHP in their Xdrive because the 704 is not available with the xdrive. The 704 is free when you get the RWD MSport and the DHP is a $3500 option. 2011 and 2012 F10 models do not offer 704 suspension in any config. and the MSport came with adjustable shocks but the dynamic sway bar were optional, starting in 2013, the DHP package included both.
06-20-2015, 09:10 PM | #3 | |
BMW Nut
50
Rep 452
I'm primarily looking to the 2010-2012 MYs due to budget, so I guess that puts me in the group you referred to - No 704 suspension regardless of configuration. How would you compare the various suspension settings on the DHP package adjustable shocks feature to the 704 package? I assume the 704 is probably equivalent to somewhere between full stiff and full soft (maybe favoring the former)? Also, assuming I were buying a 2010-12 model WITH XDrive, does that mean I would need to get the DHP package in order to get the solid suspension setup? And if so, do I need to add any options to that to get the whole deal? You mentioned the dynamic sway bar is optional, which option code is that? I'm using BMWarchive to check options packages for prospective cars, so it gives me the full skinny. Thanks again.
06-21-2015, 06:02 AM | #5 | |
Rep 29,202
The dynamic sway bars itself are called dynamic drive, option code 229. But you can't have 229 without 223, and those together are called adaptive drive, option code 2VA. So if a f10 has any kind of variable suspension, it either has just the 223 or the 2VA.
06-21-2015, 06:35 AM | #6 |
Rep 3,307
I would strongly suggest getting the full package, 2VA, especially with an xDrive. The active dampers are not enough to overcome the lack of the stiffer sport suspension on my F30 335, let alone on the bigger, heavier F10. You'll want the active roll stabilization too (sway bars, the other half of adaptive drive as remmib mentioned). I am shopping for a new F10 myself and decided it has to have DHP.
Does your E70 have the sport package? If so, it has the adaptive drive (ARS + active dampers, same as the F10). I'm not sure if at some point they took that out of the sport package, but in the '07 I had, it was included in that package, and made a huge difference in both handling and ride comfort. I'm hoping for the same on the F10. |
06-21-2015, 06:36 AM | #7 |
Rep 2,007
I had a 2015 Xdrive 535d with dynamic handling (m-sport) and it wasn't very sporty at all. I now drive a 2015 m-sport 535i, RWD with the dynamic handling package and the handling (along with so many other things) is much improved.
HOWEVER, i must tell you that while the handling is "better" its not great. I had the dynamic handling on my 2008 M3 (the comfort, sport, sport plus button) and on that car the technology was amazing, allowing the car to truly have dual personalities. The technology is not nearly as good or effective on the new 5er. In fact, often it is very difficult to tell which mode the car is in because the system is not that effective. Further I find it MADDENING that the car insists on defaulting back to the "comfort" mode every time you turn if on. Next time around I may skip the dynamic handling and the $3500 up-charge and try the M-sport suspension. The 5 isn't a sporty car. Maybe the M5 is, but I don't want or need a 110k + car to drive on a daily basis. |
06-21-2015, 06:44 AM | #8 | |
Rep 3,307
Have you driven a non-DHP xDrive, and if so, did your xDrive with DHP feel notably better? |
06-21-2015, 03:33 PM | #9 |
BMW Nut
50
Rep 452
Chrisny, like you, I've resolved to get one with the 223 and 229 options (or 2VA). BMW is maddening with their needless model year changes though. From what I've gathered, here is the progression of these particular options:
2011: Msport got the whole shooting match included, 223, 229, and therefore 2VA. 2012: Msport no longer included 229 (dynamic drive, AKA adjustable sway bar), and ONLY included 223 (as well as the aesthetic bits) 2013: Msport is now basically aesthetic only. Does not include 223 OR 229 anymore. I'm not 100% sure if this is the entire 2013 MY or just the post-LCI 2013 models. 223 and 229 now only available through the DHP package. Or possible that one could get the 223 option separately, I don't know. 2014/2015: same as 2013 as noted A few questions: 1. Is the above correct? 2. Are the option codes the same for 223 and 229 in the post LCI years. I've been doing a LOT of shopping and have found exactly ZERO models with those options in the 2013+ MY. 3. If the option codes haven't changed, what the hell is wrong with the community spec'ing out new 550i's? No one wants an actual sports suspension to match the big engine in these things? I'm stunned that it's so difficult to find a newer one with those options. Speaking to the discussion, I've owned several M3s, including a 2009 sedan with the EDC (they didn't have ADS as an option on that car, at least in 2009). Yes, the handling on that car completely blows away anything I've experienced in the 550i, but as stated previously, it's not really a fair comparison. Also, that car had a distinct lack of torque that made it a less than ideal commuter. Not so with the 550i, which also gives more space in the back. If I could afford the M3 right now (kids need to get out of daycare for that), that would be my #1 pick, but as it stands, a used 550i sounds mighty nice.
06-22-2015, 09:32 AM | #10 | |
Rep 3,307
I agree, surprised even on the 535 how many M sports are around without DHP. I was originally shopping executive demos that were pretty well equipped, but didn't find a single one with DHP. |
06-22-2015, 10:33 AM | #11 | |
Rep 2,323
The 704 suspension is about as stiff as the DHP in sport model, but it has a different feel to it. If you are buying a 2011 or 2012, the MSport package will come with adaptive suspension, dynamic sway bar is optional. The MSport in those 2 years also comes with the multi contour seats. 2011 and 2012 model year F10 had some initial design issues, you might want to do some research on it and be on the look out for those wide spread issues during the test drive. |
06-22-2015, 12:37 PM | #12 | |
Rep 29,202
06-22-2015, 07:13 PM | #13 | |
Rep 214
2013 535i M-Sport: Carbon Black with Oyster/Black Dakota, SAT, Driver Assistance Pkg, Premium Pkg, Multi-Contour Heated Seats, Navigation, H/K stereo. Michelin Pilot Sport 4S non-runflats, M5 grille, Painted reflectors from IND.
06-25-2015, 12:28 PM | #14 | |
Rep 1,472
Depends how picky you are I guess. Good luck. Last edited by Bbb34; 06-25-2015 at 12:33 PM.. |
06-25-2015, 01:38 PM | #15 |
Rep 216
For me, I felt like a 2012 rwd 535 with the 223 but not the 229 (adaptive roll bars) was the sweet spot.
The Sport/Comfort button makes a bona fide difference in the car's attitude. Activated, I am piloting The Ultimate Driving Machine. If I was leasing a new car for 2-3 years any service issues with the more complicated Adaptive Drive would be BMW's problem. As I own the car (CPO'd through June '18, but I may keep it until I find suitable manual transmission replacement.... doubtful!), long-term service concerns were a real consideration... more so than squeaking out an extra 0.03 g's. |
