BMW M3 Forum (E90 E92)
      06-20-2015, 06:15 PM   #1
Brian_Fantana
Brian_Fantana's Avatar
Drives: 09 Alpine white E90 M3 DCT
2009 M3  [0.00]
Pre-Cat O2 sensor change pics
Ok this wasn't hard but definitely not fun or easy. Total time was about 1.5 hours. I put my car up on some cheap ramps from harbor freight which gave me about 4" of clearance from my chest.
My advice:
Don't waste your time trying to work around removing the transmission cover (6 screws) the skid plate (10 screws) or the passenger side sensor shield (2 screws).
The driver side is a cake walk and only required the transmission cover off to access the sensors electrical mount.
Passenger side has a shield that will require you to remove everything else to access the mount the electrical plugin sits in.
I'm not sure how bad these look but the carbon build up looks somewhat bad. I only turned over the engine to verify I wasn't throwing any codes.
I will drive it later to see if I can feel a difference.
They've done studies, you know. Sixty percent of the time, it works every time. ~ Brian Fantana
Theodore668.50
      06-20-2015, 06:18 PM   #2
Brian_Fantana
2009 M3  [0.00]
Here are the pics
      06-20-2015, 06:23 PM   #3
Brian_Fantana
2009 M3  [0.00]
And some others
O2 sensor conditions
http://m.walkerproducts.com/o2-sensors/#conditions
      06-23-2015, 10:48 AM   #4
jdamore
jdamore's Avatar
433
Drives: 2008 e92 M3
How is she running with the new plugs and O2 sensors?
-- 08 JB e92 6MT ///M3 ESS VT2-625 --
      06-23-2015, 11:00 AM   #5
jdamore
jdamore's Avatar
433
Drives: 2008 e92 M3
For you Brian Fantana..
      06-23-2015, 06:10 PM   #6
Brian_Fantana
2009 M3  [0.00]
Haha! Love that.
She is running fantastic. I'm noticing a huge difference in low RPM power. She just seems much more eager to run. I'm not sure if it was the plugs or the O2 sensors because I didn't drive it until they were both done, but wow. It may be in my head but my butt dyno lies to no man. Especially not me
You can see from the link I posted it seems like my engine seems to be running on the rich side as well. Perhaps this fixed or helped that? IDK but well worth the time it required.
      11-11-2015, 10:41 AM   #7
ONE_slow_m5
Drives: 2020 f90 m5
Originally Posted by Brian_Fantana View Post
Haha! Love that.
any pics where these sit ?
2020 BMW m5 f90 Project gamma intake downpipes charge coolers . Awe Exhaust Pure_performance_TX stage 3 build motor e40 ABP tune snow performance meth kit
2018 x6m Built motor stage 3 tune PG downpipes
      11-11-2015, 05:57 PM   #8
atruelunatic
Drives: n/a
Adding to the previous question, do you have the size wrench and torque values for the sensors?
2011 e92 JzB 6MT
Akrapovic Evolution, ESS Tune, KW V3
      11-18-2015, 01:54 PM   #9
Brian_Fantana
2009 M3  [0.00]
Sorry I don't remember now. I want to say 15mm open head wrench but I can't remember.
      11-18-2015, 08:02 PM   #10
ONE_slow_m5
Drives: 2020 f90 m5
7/8th will do
      09-27-2016, 01:09 AM   #11
Theodore
Theodore's Avatar
Drives: 2011.5 E92 M3
Thanks for the write up! For those tackling this job, these pre-cat O2 sensors require a 22 mm open-end wrench (7/8 inch is nearly the same size). Unfortunately the electrical plug end of the sensor is too large to fit through a ratcheting box-end wrench and there is not enough space to successfully use an O2 sensor socket, so you are stuck using an open-end wrench on this job.
To make removal of the old sensors a little easier:
A. Try to do this job while the exhaust is still warm (but not "burn yourself" hot)
B. Spray some Liquid Wrench on there to soak in the threads for a good 20+ minutes before removal
C. Help break the corrosion by slightly tightening the sensor onto the exhaust (maybe a 5 degree turn) before trying to loosen the sensor off the exhaust.
Here is a picture of my unsuccessful attempt to use an O2 sensor socket.
      11-17-2016, 11:45 PM   #12
TWiTCHY
TWiTCHY's Avatar
Drives: '13 AW E92 M3
I've been told to use a thread chaser after removal, but can anyone attest to skipping that step or performing Theodore's tip?
      11-17-2016, 11:56 PM   #13
JsL
Drives: 2011 AW M3 ZCP
Can you take a pic of where to press on the connector to disconnect the sensor from the harness?
      12-12-2016, 05:47 PM   #14
111turbo
111turbo's Avatar
81
Drives: '12 e92 M3
Great advice! I just got my precat sensor changed also and car seems to run a bit smoother.
m3post
