06-18-2015, 08:33 PM | #1 |
Rep 6,708
Valve cover gasket DIY
Looked around and surprisingly I could not find a DIY for replacing the valve cover gaskets.
Anyone have the TIS, pictures, torque specs, and tightening pattern etc.? |
06-23-2015, 03:50 PM | #3 |
Rep 1,792
Here you go bud
http://workshop-manuals.com/bmw/3_se...ver_%28s65%29/ http://workshop-manuals.com/bmw/3_se...ad_with_cover/ 10NM for the tightening torque Last edited by Leonardo629; 01-02-2017 at 09:51 PM.. |
sungjungsc18.50 zstreet86116.00 |
06-23-2015, 06:33 PM | #4 |
Rep 6,708
Thanks! Forgot all about that site
Not to sound like an ingrate but I see the torque should be 15 Nm and 17Nm for the oil trap to cover http://workshop-manuals.com/bmw/3_se...ad_with_cover/ Is it really that easy per the guide? The pictures make it seem so easy because the engine is on a stand and not in a engine bay lol |
07-22-2015, 05:59 PM | #5 | |
Rep 6,708
User alxmlr789 did the valve cover gasket using OEM gaskets.
http://www.m3post.com/forums/showpos...5&postcount=18 Quote:
11-09-2015, 03:33 PM | #8 |
Rep 876
11-10-2015, 08:26 PM | #10 |
Rep 2,491
Yep, no DIY.
I will add some advice, look into replacing the bolts - more specifically the "crush grommets" that are seated in the valve cover. These tend to leak after they have been reused, and unfortunately they only come with the bolts. 4.75 per bolt/grommet. This was the source of one of my leaks. Also, pay close attention to when you reinstall the crank case breather. The metal sleeves that bolt to the valve cover seemed to be a bit loose, which let the breather pull away from the VC and spews oil all over the place. What a stupid design. I used a set of small washers to essentially "lock" the sleeves into the breather. May not happen on every job, but sure was a pain in the ass on mine. |
M3MPH1S592.00 |
02-09-2016, 01:55 PM | #11 |
Rep 734
Im, going to be doing this as well since my Passenger Side Gasket seems to be seeping (didn't take time to investigate, but i see oil stains.) Doing it soon with my Indy that will also be doing the Throttle Body Actuators at the same time.
Question. I found the parts for the gasket no problem, but anyone know the PN for the bolts? (will be replacing all of them, might as well) Also, how many will i need for the whole job? Thanks! PS. my oil filler cap is also leaking... many posts on this already, but anyone can chime in the most effective way to fix that? Or just simply buy the updated cap every other time i change my oil. (My OCI is quite frequent.... usually every half year or 7500-10,000km which ever comes first). Thanks!
94' NSX - Garage Queen
97' Integra Type R - Track Warrior (Sold) 01' BMW E39 M5 (Sold), 2x 02' BMW E39 M5 (Sold & sold) 08' E90 M3 6MT - DD 13' W212 E63 AMG Wagon |
02-09-2016, 07:26 PM | #12 | |
Rep 875
02-09-2016, 09:59 PM | #13 |
Rep 6,708
Another tip that might work is to bend the ears back on the underside of the cap. This will allow the cap to sit tighter on the gasket seal.
04-03-2016, 02:40 AM | #14 |
Rep 18
Are you sure the tightening torque spec is 15nm ? Because according to real oem the valve cover bolts are M6 which state need to be 10nm. Can someone confirm this ? Thanks
04-03-2016, 02:00 PM | #15 | |
Rep 2,491
2010 E92 M3 DCT
09-25-2016, 03:37 PM | #18 |
Rep 162
I'm doing it right now. One valve cover off. I'm taking my time as this is my second car. Gasket and new bolts won't come in from ECS until later this week.
2011 X5D
Previous: 08 E92 M3, 11 335D, 11 328i |
09-25-2016, 04:15 PM | #19 |
Rep 1,755
09-26-2016, 10:45 AM | #20 |
Rep 2,491
Make sure you cover up your motor while the covers are off.
2010 E92 M3 DCT
09-26-2016, 03:20 PM | #21 |
Rep 225
In case anyone is interested I found the part number on the Bolt/Grommet
11127841217 BMW told me they dont stock the E9X valve cover gaskets nor this bolt because they never leak. I asked why I had oil on my spark plug threads. He response was "you should just pay and have it diagnosed." He wasn't aware I just picked my car up on Friday after BMW had kept my car for 3 weeks. #hardpass
They've done studies, you know. Sixty percent of the time, it works every time. ~ Brian Fantana
09-26-2016, 06:55 PM | #22 |
Rep 6,708
I don't think my gaskets are leaking either. I believe based on the trail of oil, that it's coming from my oil filler cap.
I don't know about never leaking though... Smh at some dealers.. |
