06-15-2015, 02:34 AM | #1 |
Rep 498
Installing IND reflectors: tips on disconnecting sensors?
I've got an F36 with the side view cameras and parking assist. So this means there are sensors in the front fender right next to the orange reflectors.
I have the IND painted reflectors and I'm planning on installing this week. However I wanted to know in advance if there are any tips with disconnecting the sensors I need to know about? Will they be straightforward to disconnect once I peel back the fender liner? |
06-18-2015, 10:55 AM | #2 |
***** noob
1370
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
No need to disconnect, search the DIY thread and just read the last few post on what to do
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
06-18-2015, 11:14 AM | #3 |
Rep 75
When installing new painted reflector don't try and install it from the fender wheel well. Put it through the reflector hole with one hand behind and guide it in with the other otherwise you risk scratching it trying to go behind the bumper cameras and wires
06-18-2015, 01:43 PM | #4 | |
Rep 498
06-18-2015, 01:50 PM | #5 |
***** noob
1370
Rep 10,479
Just heat the reflector for a good 5-10 minutes (hairdryer or heatgun at low)
The adhesive will start to give way and just push the reflector in. Wear gloves..DO NOT use any type of pry tool Yes its really that simple
2006 325xi (Sold)
06-18-2015, 01:52 PM | #6 | |
Rep 498
06-18-2015, 01:56 PM | #7 |
***** noob
1370
Rep 10,479
Haha u still need to pull the plastic fender out of the way
But no need to remove sensors
2006 325xi (Sold)
06-18-2015, 06:03 PM | #8 |
Rep 75
Yeah that's fine. Didn't care about scratching the ugly Orange one
06-18-2015, 06:52 PM | #9 | |
Gettin It Figured Out
1820
Rep 2,669
06-20-2015, 08:40 PM | #10 |
Rep 498
Ok I tried this today with a heat gun and couldn't get them out, so gave up because I ran out of time.
I opened the fender liner by removing the four screws with an 8mm hex. Using a heat gun on low, I heated the reflector some the outside (so paint side) since I couldn't heat from the inside due to the sensor and camera there. After 5 minutes, I tried pushing the reflector in but it wouldn't budge. Heated it up again some more for another 5 mins and still wouldn't budge. I felt like I used quite a bit of force but didn't want to risk pushing any harder at risk of damaging the fender or surrounding paint. I ending up burning the tip of my finger a bit from the hot reflector so I know it was fairly warm. (I originally was planning on using work gloves to protect my hands but my gloves are way too thick which reduced my ability to get inside the fender). I avoided heating a lot more at risk of melting the plastic or something else. I'm thinking I need to use a screwdriver or something for leverage to pry from the inside to get it to move just a bit. Any other tips? |
06-20-2015, 09:01 PM | #11 |
***** noob
1370
Rep 10,479
You didnt heat it enough, or you heat the reflector and not around the reflector. Wear gloves
Dont pry it'll dent your bumper
2006 325xi (Sold)
06-21-2015, 01:51 AM | #12 | |
Rep 498
06-21-2015, 05:13 PM | #13 |
Rep 75
Heat around the reflector where it meets the bumper. Just don't keep the heat in one spot. Do circular motions with the heat gun. Then press on it and it should loosen up more and more. Don't put heat gun too close either
06-21-2015, 07:49 PM | #14 |
1820
Rep 2,669
^^ +1 The key is heating around reflector in a circular pattern
06-22-2015, 12:38 AM | #15 | |
Rep 498
06-22-2015, 08:00 AM | #16 | ||
***** noob
1370
Rep 10,479
The adhesive will give in once it reach certain temp.
2006 325xi (Sold)
06-22-2015, 09:00 AM | #17 | |||
Rep 498
