06-08-2015, 08:07 AM | #1 |
Rep 477
F30 OEM Auto Shift Knob Replacement
Just wondering if anyone has tried replacing the auto shift knob with say an F10 M5 DCT knob or the like? Having searched around haven't really seen it done....
06-08-2015, 11:20 AM | #2 |
BimmerPost Supporting Vendor
569
Rep 987
Drives: 2022 X4 M Competition F98 LCI
You can only interchange the following shifters
205 Steptronic Automatic 2TB Sport Automatic Reason is that there is an ECU in the shifter and that the DCT shifters (from say the M3/M4) have a different ECU due to it's dual-clutch transmission vs the normal ZF found on the F30 range. |
06-08-2015, 03:12 PM | #3 | |
407
Rep 676
06-08-2015, 03:34 PM | #4 | |
569
Rep 987
Here are the part numbers for the 2TB Sport Auto Shifter (Leather boot) 61319260970/61319291520/61319296898 *From Oldest to Newest P/N - Also easier to search by last 7 digits on eBay. To install, just remove the iDrive trim (hands work), the shifter surround, Driver Experience/PDC controls and the centre console surround (only needs to be lifted from the rear) to have access to all 4 screws. Remove, unplug and install in reverse order. Should not require programming or coding once installed. During Install Installed Hope that helps! |
AndrewC198910931.00 DLag30103.50 |
06-08-2015, 03:48 PM | #5 |
Rep 614
Drives: 2016 F36 M Sport
What are the differences between the 205 Steptronic Automatic and the 2TB Sport Automatic shifters? Is it just the slightly different shape and leather boot?
2016 BMW 428i Gran Coupe, M Sport, Glacier Silver Metallic
06-08-2015, 04:00 PM | #6 | |
569
Rep 987
Though if you had optioned 2TB from the factory, it'd also be the added paddle shifters and the Sport programming - which you can code by changing your VO from 205 to 2TB and VO coding ICM, KOMBI, EGS and FEM_BODY (if I remember correctly.) |
DLag30103.50 |
06-10-2015, 06:49 PM | #7 | ||
Rep 61
06-10-2015, 11:59 PM | #8 | |
407
Rep 676
06-25-2015, 02:03 PM | #9 | |
Rep 1,637
I'v been thinking about it for while. Mine is f32 |
06-26-2015, 01:20 AM | #10 |
Rep 477
Don't believe so, even though the mounting points look slightly similar, according to Timbits93 the insides of the knob are different. Would have been keen to do the swap if they were interchangeable...
07-12-2016, 06:43 AM | #12 |
Rep 30
My 330e has 205 Steptronic Automatic and the paddle shifters.
If I would code the 2TB Sport Automatic, will it all work with my standard shift knob and paddle shifters? |
07-12-2016, 09:03 AM | #13 |
A family of bimmers
2748
Rep 7,742
I believe so as adding 2TB is just reprogramming how the transmission shifts
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
07-12-2016, 11:43 AM | #14 |
Rep 30
Ok thanks.
I was under the impression to have a 205 gearbox but I have this one: S2TEA Automatic transmission w shift paddles Any idea what the difference is? |
07-12-2016, 12:16 PM | #15 |
A family of bimmers
2748
Rep 7,742
Didnt realize you have the hybrid model so its possible that will not work for the s2tea
07-12-2016, 06:26 PM | #17 |
Rep 2,200
It's like wheels - different strokes for different folks.
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
ArizonaErik95.00 |
03-28-2017, 12:24 AM | #19 |
Rep 49
So this guy in China got the F80 gear selector to work in his F30, but he said it was the shop he took it to that figured out the coding. I don't know if this would be possible in the US, but I would be all over it if it were.
http://f30.bimmerpost.com/forums/showthread.php?t=1330524&page=2 |
08-22-2017, 09:57 AM | #21 |
Rep 374
Drives: 2017 540i
^^ anyone?
2017 540i :: 2006 M3 :: 2012 328i Sport Line (sold)
