06-03-2015, 10:30 AM | #1 |
Rep 1,455
LED Lights Coded
Since I got my LED'S coded to Euro Spec everything has been working fine. I finally drove at night on Saturday for a longer than usual drive. The lights worked amazingly good, I never got a high beam from the opposite direction, however, I did see people hitting their brakes because I think they were confused as to what my lights were doing. The high beam assist works much quicker than I could do it manually and all the signs on the street really light up very well. Before I got them coded I was kind of disappointed in the brightness of the lights, I didn't think they were any different than regular lights. Once coded it's a different world.
Also the lights turning when you turn the steering wheel probably confuses other drivers. I don't think it is dangerous at all just that motorists have to get use to it. I had a motorist pull up next to me and ask what kind of car is that and also inquired about the lights. |
06-03-2015, 07:35 PM | #3 |
Rep 3,998
Isnt this standard when you have LED's, mine was already coded from BMW, ED guy told me that was a cool function and indeed it was.
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
06-03-2015, 08:02 PM | #4 |
Rep 324
06-03-2015, 08:29 PM | #5 |
Rep 3,998
That's why,
06-04-2015, 09:48 PM | #7 |
Rep 382
I have to re-code mine and find better instructions of what exactly to code. I followed a thread instructions but i don't think its working well. Or maybe it gets activated at a certain speed? In any case, when i press the auto button the blue high beam turns off, and the other way around too. The blue high beam light does not come on by itself and turn off by itself as i understand it needs to happen.
Congratulations, looks like you got it working
Current: 2015 BMW F80 M3
Retired: 2012 BMW 335is Other: 2014 Mini Cooper |
06-08-2015, 01:51 PM | #8 |
Sakhir Smurf
314
Rep 594
Drives: Plaid, F82 M4, E46 M3, Sequoia
You need your headlights to be on "auto", not turned on manually (using the rotary button to the left of your wheel). Then when you press the button on the stalk, you'll see a little green light with the A - that means the system is turned on.
On that note, does anyone know how to enable the auto high beams w/o the headlights being on "auto"?
2015 M4: Sakhir on Sakhir | M-DCT | Adaptive Suspension | Lighting | Executive | Cameras | HK Sound | Full Leather
2004 M3: Laguna Seca Blue | SMGII | Basic track mods: 18" Square setup on R888s / Performance Friction rotors / SS Lines / Ground Control Street/Track Kit / DTC-60 Pads NASA NorCal Instructor |
