European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      05-26-2015, 10:33 AM   #1
JoeFromPA
Drives: '15 AW M3 6MT Stripper
Minor malfunction - seatbelt chime on pass seat went off due to iphone weight
Just thought I'd share this: Yesterday after getting gas, I was driving for about 30 seconds when my seatbelt chime started going off.
I un-did and re-did my seatbelt a number of times and it was still going off. The only thing on my pass seat was my iphone, so I thought - might as well lift it.
Instantly went off
So apparently, for some reason on this trip, the weight of my iphone was enough to trigger the passenger sensor.
AW/Carbonstructure 6MT 2015 M3 picked up 8/22/2014. Stripper except for adaptive suspension. Weighed at 3,450 pounds with 1/4 fuel. 70,000 miles as of February 2020.
      05-26-2015, 03:20 PM   #2
Stage1
Curiosity Killed the Cat
Stage1's Avatar
241
Drives: M4 GTS
2021 BMW M4  [0.00]
2016 M4 GTS  [8.00]
2016 Cayman GT4  [0.00]
2016 Wrangler  [0.00]
Had this happen to me once when my phone got wedged in the crack of the passenger seat
SOLD - 2015 /// F82 M4 / AY-SO
"AY-BRAVE"
I'M BACK - 2016 M4 GTS
I'M BACK AGAIN - 2021 M4 COMP FPB
      05-26-2015, 10:08 PM   #3
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
Code the alert off. Problem solved
Daily: G12 750 MSPORT Weekend Car: E90 M3
      05-27-2015, 05:37 PM   #4
Racer20
Drives: F80 M3, 228i THP, E46 ZHP
Happened to me a couple times this winter in my 228i. I don't think I've seen the issue in my M3 yet.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
      06-02-2015, 09:42 PM   #5
fchris
Drives: 2015 M4
Just reach up and turn the Passenger Air Bag off. Seat sensor will then be turned off.
      06-02-2015, 09:43 PM   #6
Jaymax85
Addicted to Speed.
Jaymax85's Avatar
Drives: m3 zcp, macan GTS, f15 x5
Happens to me too
      06-03-2015, 07:49 AM   #7
morgan302
Drives: m3 2015
2015 M3  [0.00]
2015 BMW M3  [0.00]
Get a lighter phone
      06-04-2015, 12:04 PM   #8
rebirth24
rebirth24's Avatar
51
Drives: 2015 F82
2015 BMW M4  [0.00]
This doesn't happen with Android based phones...just saying...
      06-08-2015, 02:37 PM   #9
DaBean
Sakhir Smurf
314
Drives: Plaid, F82 M4, E46 M3, Sequoia
2002 BMW X5 4.4i  [0.00]
2015 BMW M4  [0.00]
2004 BMW M3  [0.00]
+1 on coding these off...
2015 M4: Sakhir on Sakhir | M-DCT | Adaptive Suspension | Lighting | Executive | Cameras | HK Sound | Full Leather
2004 M3: Laguna Seca Blue | SMGII | Basic track mods: 18" Square setup on R888s / Performance Friction rotors / SS Lines / Ground Control Street/Track Kit / DTC-60 Pads
NASA NorCal Instructor
      06-10-2015, 12:46 PM   #10
Jockey
Jockey's Avatar
3445
Drives: 992 C4S
Yep, it annoys me that a 6-pack of beer on the seat will cause the chime.
      06-12-2015, 10:47 PM   #11
Ian1973
Drives: 15 M3
That was a problem with the E9x. Mine would do it with nothing on the seat if the cabin was over like 75 deg F. It was so irritating. I had to run with the passenger seat belt clipped.
      07-23-2015, 07:50 AM   #12
Racer20
So apparently modern seat occupancy sensors use electric fields to determine the water content of the object in the seat rather than just using a weight sensor. This eliminates the issue of mistaking a heavy object for a person, but it makes the system susceptible to EMC interference from electronic devices.
This happens to me about once a month or so, now I know why. Don't bother going to the dealership, nothing they can do about it.
      08-12-2015, 07:34 PM   #13
BuLoOoSki
Kuwait
749
Drives: 2015 BMW M3
I have a Nexus 6, which I believe is even heavier than an iPhone 6 Plus, but I've never encountered this issue.
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs
      08-31-2015, 10:32 AM   #14
Greeney
Greeney's Avatar
Drives: Jerez E90 M3
I had to code the seatbelt chime for the Pax seat to off because of this... Very annoying.
      11-09-2015, 10:08 PM   #15
eduardko
Drives: M4 Convertible
So how to you code this off? Is it a DYI, or needs to be done at a shop?
      11-11-2015, 09:27 PM   #16
evanescent03
evanescent03's Avatar
1032
Drives: '24 M3 CS; '22 GT4
I see you beat me to this thread. . I searched but couldn't find anything and started a very similar thread a while ago. my car had mysteriously stopped being so sensitive. I wonder if they updated something when the car was in for the 1200mi beak in service. .?
Gone but not forgotten: '09 STi // '08 335i // '02 M3 // '11 335i // '15 M3 // '16 M3 // '16 Camaro SS // '16 Audi S3 // '18 Boxster 718S // '17 Camaro SS 1LE // '16 M6 GC CP
      08-02-2018, 10:44 PM   #17
doug_999
doug_999's Avatar
2542
Drives: 2011 1M/2021 992/2023 X3
Wow, just had this twice in last two weeks. Only happens with phone charging. Dealer said they are seeing it a lot more these days.
2011 1M, Black loaded sans sat radio
2021 911 C4S Gentian Blue, manual
2023 X3 M40i - loaded sans Park Assist
      06-19-2023, 05:54 AM   #18
natedawg469
F82 M4
Drives: 2015 BMW M4
It finally did in 2023 in my 2015 bmw m4, lol.
f80post
