05-25-2015, 04:39 PM | #1 |
Rep 111
M Perf steering wheel questions
Hi Guys,
I am currently thinking of changing my M-Sport steering wheel with M-Performance steering wheel II with race display. I have couple of questions to the guys that have the M-Perf steering wheel with race display: 1. I have heated steering wheel. If I change the steering wheel to M-Perf, do I loose the heating option? 2. Do you need to change airbag to go from M-Sport to M-Perf? 3. I have an automatic gear box. Are gear shift indicators showing the shift points when the gearbox is shifting gears on automatically or gear shifts are only operating when gearbox is in manual mode? 4. Can you set specific RPM at which the lights indicate you to shift the gear or it is set automatically? Thank you for your input! |
05-26-2015, 02:10 AM | #2 |
Rep 826
Drives: 2017 C43 AMG
You will lose the heated steering wheel. You can use the same airbag. It doesn't need to be changed.
2014 X5 xDrive50i Mineral White | DinanTronics Stage 1 | Vossen HC3
06-02-2015, 01:45 PM | #3 |
Rep 24
I ordered a M Performance Steering Wheel (the flat bottomed one) today, but as I have the normal automatic (without paddles) I chose without race display, as I see absolutely no need for it, the gearbox handles the shifts anyway.
