E92 Headlamp assembly has water.
05-13-2015, 02:39 PM | #1 |
Rep 9
I have a 2008 BMW 335xi E92. My headlamp has a lot of condensation and it caused my HID bulb to go out. I took my whole headlamp out and found that it was a lot of water inside. I think water was in the Ballast as well. I took the HID bulb out and it was blown. I got as much water out as possible. I put everything back together minus the bulb because it needs to be replaced. I've been driving with just my Halogen/daytime running lamps, waiting on my replacement HID Bulb. A day later of driving I noticed a lot of condensation was built up again. So obviously the headlamp unit is not sealed properly. I also feel like the water probably shorted out the ballast. I need some kind of help on what to do.
Check attached photos. Does anyone know about this headlamp assembly? How easy is it for the ballast to get shorted? Can I reseal or do I need to replace it? It seems like the unit price is around $600. Is that fair? Can this unit be rebuilt? I appreciate any suggestions. -Akim
-KiRocka-
05-13-2015, 02:44 PM | #2 |
Rep 2,283
How handy are you?
If it were me, I would bake it or heat gun the lense off. Apply a new layer of sealant, put it together and a final bake to finalize the seal. (DIY - ) If you don't feel comfortable doing this your gonna have to just buy a new one. Regarding the ballast, keep water off it and you will be good. I would be weary putting a new bulb in without fixing the seal as you could burn out the ballast which isnt cheap to an already expensive problem. Hope this helps!
05-13-2015, 03:01 PM | #3 |
Maximus Decimus Meridius
1130
Rep 4,584
I've always wanted to give that orion upgrade a shot but it looks like they have to break the old rings to get them off and that is just not something i feel comfortable doing lol..
F30 335i Melbourne Red Metallic M-Sport Package |
05-13-2015, 03:13 PM | #4 | |
Rep 9
Thank you Tim. I think I will give it a shot. Worst Case I'll just have to get a new one.
I'll let you know how it turns out. Quote:
-KiRocka-
05-13-2015, 03:38 PM | #5 |
Rep 460
check out this post.
I think its all fixable and they maybe able to do upgrade for the price what you would pay to have it replaced. http://www.e90post.com/forums/showthread.php?t=1111238 |
05-13-2015, 07:51 PM | #7 | |
7425
Rep 10,228
If you take your time it's really not that difficult. It just takes time and patience. However if you're not comfortable with replacing the rings and want a permanent solution, you have 2 options: You either DIY or you ship them out to a company like Lightwerkz to reseal them. If you DIY, it'll cost you about $15. All you'd need to do is bake the headlight in the oven, yes I know it doesn't sit right in anyone's head, but it really is very simple. Baking them at I believe 215 degrees for 8 minutes will loosen up the sealant as you pull off the lens. After that, you'll apply butyl rubber, DO NOT use any other silicone or sealant. The butyl is your only expense here at $15 and you can buy it at Lightwerkz or ebay. You throw the butyl in the seal, throw it back in the oven, and you're done. |
05-13-2015, 08:31 PM | #8 | ||
1130
Rep 4,584
05-13-2015, 08:35 PM | #9 | |
7425
Rep 10,228
05-13-2015, 09:01 PM | #10 | |
1130
Rep 4,584
Tags |
2008 335xi coupe, headlamp |
