proTUNING Freaks
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      05-13-2015, 10:43 AM   #1
McButtLovin
Drives: 2015 M3
Manual Transmission Clutch feels clunky at times
So i've had my 2015 M3 for about 2500 miles now. I've started noticing a clunkyness to the clutch, when it is depressed to downshift or change gears that seems to make more than normal noise. It's clunky and feels like it's old.
I have been driving MT cars for over a decade and haven't had a problem with any one of the clutches, esp. this soon. I'm not sure what's going on. I had the 1200 mile service done and since then in 1st and 2nd gear, the way the car feels doesn't sit well with me when I keep hearing mechanical noise and clunky sounds when I downshift.
Very occasional i've heard a rattling and I don't know where it's coming from as nothing is dragging on the road from underneath.
      05-13-2015, 12:42 PM   #2
gsrbri
gsrbri's Avatar
Drives: F87 6MT
The uprated clutch will rattle a bit on clutch engagement, and coasting w/the clutch in, just as the E9X M3 did. It's the clutch disc springs as the disc moves (rotates) on the input shaft to the 6MT gearbox.
Other noises, are you sure they are transmission/clutch related? My 6MT F82 works smoothly, effectively (both on the street and during my first track day back in late April). As I mentioned, the clutch does rattle a bit (three quick rattle-rattle-rattles, w/the noise coming from under the car w/the windows down, when the clutch is pushed in (and if you are coasting w/the clutch in).
Can you give us some more information/description?
      05-14-2015, 05:03 PM   #3
McButtLovin
Drives: 2015 M3
There's been some occasional rattling/scraping sounds, but I read on this forum that this might be due to other things occurring relating to rocks/pebbles stuck in between or something about the emergency brake line?
I'm taking the car to the BMW dealer tomorrow to see what they have to say about the clutch and stuff. It could be normal but it just seems to disengage in an abrupt clunky way and it doesn't feel that smooth as my old 135i was.
      07-28-2015, 05:12 PM   #4
MAC 1977
Drives: 2015 San Marino Blue M3
Did you ever get this figured out? Mine seems to be doing the same thing at very low speeds, shifting from 1st to 2nd, you hear this weird rattle and slight clunk.
      08-09-2015, 07:58 PM   #5
Reid
Reid's Avatar
253
Drives: white cars
Originally Posted by Railgun View Post
As it's a twin-plate clutch, I would assume that would have something to do with it.
I've not driven an OEM twin clutch, but my 7 with its aftermarket twin clutch was a bit noisy at engagement. I'd attribute it to being normal. As I've not yet picked mine up, nor had I driven a MT M4 for the test drive, I'm making a small assumption here.
That's all it is. Normal twin disc sounds.
      09-04-2015, 06:24 PM   #6
Donger Kim
Drives: MY16 M3
I actually get this sound from going from 1st gear to simply depressing my clutch. I heard this as I was driving away from the welt and never really felt great about it since
      09-04-2015, 06:43 PM   #7
aramz09
aramz09's Avatar
Drives: F80 2016
Man, all these posts on MT problems. Almost regretting on my MT build that's currently being shipped. Can we have some MT drivers chime in on their experience with their M3/M4. Thanks.
      09-04-2015, 06:54 PM   #8
saxon
Drives: s4
their not problems, just people arent used to a heavy duty clutch, and a drivetrain thats pretty much directly connected to the chassis so you hear/feel more than you would on any normal car
2015 f80-Mineral White- 6spd mt- 19" silver-HK-Adaptive Susp-carbonstructure-carbon roof- cbtuning.net flash tune, 465hp 510tq
      09-04-2015, 08:59 PM   #9
IcebergM4
IcebergM4's Avatar
361
Drives: '23 M4C
Well I don't know what all the fuss is about but my 6MT is PHENOMENAL! I will agree that the transmission does feel slightly rough in Sport Plus (M2 for me), but it's definitely not disappointing or off-putting in any way. The 6MT on this car is the smoothest and the most rewarding I've ever driven. Period.
      09-07-2015, 04:27 PM   #10
vasi_M3
vasi_M3's Avatar
116
Drives: Ex- 2015 M3... now '16 M3 ZCP
I've experienced the same loud audible sounds coming from the engagement of the clutch, mostly when trying to put the car in 1st or 2nd. I too was wondering if it's due to the nature of twin clutch or whether it's something else. I haven't figured it out yet however the dealer says its normal. As far as the 6MT I feel like it's a gem of a transmission. Dot think I've ever driven something this good. The only thing that doesn't match the character of the transmission is the Sport Plus mode of the throttle response , seems like I'm always giving a little gas with the clutch still engaged , so I just keep it in Sport most of the time.
      09-07-2015, 08:27 PM   #11
susuki1220
Drives: m4
for me the clunkiness comes from 1st gear switching to 2nd if the rpm is around 2000rpm.
And i have also notice the rpm drop is different no matter how fast i shift nor my golden left foot clutching in. 1->2 [ 1200rpm drop at least ] 2->3 [ 1000rpm drop ] 3->4 [ lower rpm drop] and goes on, you get the idea.
And i think the 1200rpm drop creates the clunkiness to the clutch imo.
      09-08-2015, 04:44 AM   #12
Donger Kim
Drives: MY16 M3
this is exactly my experience. I've always thought it was because I was doing something with the clutch and the shifter incorrectly. It just feels like I'm driving an old truck at times.
      09-08-2015, 08:54 AM   #13
MaynardZed
MaynardZed's Avatar
Drives: wife crazy
Gentlemen, the clunk you're hearing/feeling is not the clutch. Its lash from the carbon driveshaft. It's light and hollow, so when you disengage the clutch out of 1st gear it gives the driveshaft a bit of clunk since the drivetrain mounts are very stiff otherwise. Very normal, but does feel like its coming from the trans, since the driveshaft is directly connected.
You shouldn't feel it in higher gears.
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352
Road course laptimes for Porsche 911 991.1 GTS 7MT
WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889
      10-10-2017, 09:07 PM   #14
rakusak
Drives: E82, F15, F80
Would this include downshifting? Need to test it again when i get mine stateside, but it seemed like a clunk or thud when i downshifted 5-4, 4-3, or even 3-2.
      11-21-2017, 07:21 PM   #15
Paz1
Drives: 2018 m3
I seem to be having an issue that most above have stated. Car only has 800 miles but the last 100 I feel that in SPORT coming off on first once it a blue it makes this squeal type of noise and always from 3->2. In comfort there isn’t any issues. I have a vid but it can’t post so pm ur number and I can send the vid of the noise. Any solution to this issue ?
      02-13-2018, 06:34 AM   #16
Ravcik
Poland
11
Drives: 2015| M3 | Manual Transmission
Same Issue Here
Same loud sounds coming from the engagement of the clutch, mostly when trying to put the car in 1st,2nd and 3th gear. This is really anoying.
Here is a link to the video:
https://megawrzuta.pl/download/eebfd...e9a853ef0.html
f80post
