Brakes
05-05-2015, 12:07 PM | #1 |
Member
15
Rep 78
Brakes
Hello all, I have a 330i with sport package. I have noticed that my brake pedal is much softer than when I purchased the car a couple of years ago. When I first bought the car, I actually googled about the brakes on the car as they would grip extremely hard that I thought it was almost not right. Now, the brakes seem weaker. I would say that they are not any less effective and if you jump on the pedal, the car quickly stops. The pedal just travels further and feels more spongy than it used to. Nothing has been done to the brakes in the last while so there shouldn't be any human error or poor workmanship at hand.
Any thought? Thanks! |
05-05-2015, 12:12 PM | #2 | |
Rep 213
Drives: 2011 335i xDrive
05-05-2015, 12:16 PM | #3 | |
Rep 989
05-05-2015, 02:26 PM | #4 | |
Rep 2,109
05-05-2015, 04:31 PM | #6 |
Rep 2,136
Flush your brake fluid. After years in the system, brake fluid absorbs air. Liquid is not compressible but air is, so when you press the brake pedal, the pressure in the braking system will increase over 500psi, all the tiny air bubbles in your braking system will compress and give that "mushy" feeling to the brake pedal.
06-13-2015, 10:26 AM | #8 |
Rep 2,189
If you did a correct flush and there's no leaks, your pedal feel should be back to factory specs.
So its either in your head or you didnt flush correctly.
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
