335i xdrive coupe - upgrade to m3 control arms
04-27-2015, 12:10 AM | #1 |
Rep 117
Hi guys, looking for some answers here. I am looking at the following control arm from autopartsway.ca for my 2011 335xi coupe:
http://www.autopartsway.ca/partdetai...33-1779604/trw The TRW part number they refer to is: TRW1779604. Is this the correct part number for the tension strut? Autopartsway.ca does not seem to have this part under 2011 bmw m3 but rather under a bmw x1... I can't seem to find this part number anywhere else. Thanks for the help! |
04-27-2015, 07:50 AM | #3 |
Rep 2,202
Link does not work..
Key to note that the M3 front control arms may not work on Xdrive platform.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
04-27-2015, 10:06 AM | #4 | ||
Curmudgeon and Pedant
690
Rep 3,489
http://www.realoem.com/bmw/showparts...14&hg=31&fg=05 http://www.realoem.com/bmw/showparts...40&hg=31&fg=05 |
04-27-2015, 10:09 AM | #6 | |
Rep 117
04-27-2015, 11:49 AM | #7 |
Rep 166
I've been waiting for a moment like this to tell you guys about xdrive bushings.
I replaced both the front control arms bushings in my xdrive for this same reason. Originally I got ahold of strongflex and they sent me a set of rear bushings and a set of front bushings. But the front control arms bushings are different than they are on the non x-drive (everything here is in reference to the 2 front control arms, front is the front control arm closer to the front, rear is the front control arm closer to the rear). The rear control arm bushing worked great though, but you will NEED a press to get it in. I was having issues with pulling hard one way or the other under braking, completely solved the problem. The front bushing they sent me though was for the non xdrive/xi and wouldnt fit. I emailed them back about this and they were kind enough to make me a custom bushing after I sent them some xi control arms. They work great as well! Not sure they are going to go into production with those front control arm bushings or not, but you can sure email them. Yep, I dont see the front control arm bushing listed on their site, but here is a link to the rear: http://www.strongflex.eu/en/e90-e91-...4x4-sport.html
BMS DCI, BMS OCC, VRSF stepped 5" FMIC, VRSF CP, VRSF DP's, SPEC stage 3+ and SMFW, PRW stage 3 LPFP, MHD custom E85 tune, solid motor mounts, RB PCV valve, SS brake lines, Prospeed RS683 brake fluid, Strongflex poly bushings, VTT inlets, M3 rear control arms, ECS trailing arms, turbo smart DV's, CP-E PI, VTT HS CP, UUC short shifter, custom solid transfer-case mount, RBTurbo vacuum side OCC, PRW upgraded ignition coils.
04-27-2015, 12:20 PM | #8 | |
Rep 117
What are your guys' thoughts on lemfoerdor? Autopartsway seems to carry direct replacements (bushings sold separately I believe) for both of the front control arms (front and rear). They indicate that it will fit an xdrive model as well. http://www.autopartsway.ca/partlist.cfm?bmw/2011/335i-xdrive/base/3l-l6/allb/suspension/suspension,-springs-and-related-components/suspension-control-arm/pagenum1/tabs |
04-28-2015, 07:53 PM | #9 |
Rep 117
Okay guys, I am somewhat confused here. I have decided that I am going to go ahead and replace just the control arm bushings on my 335xi. How many bushings to do I need to purchase so that all the control arm bushings are replaced?
I originally thought just 2, one per control arm (wishbone). But do the tension struts have the same bushings? So I'll need 4? |
04-29-2015, 04:05 AM | #10 |
Rep 2,109
For front there is one bushing that is sold separately, it is number 9 there. I don't know if the bushing on 15 is replacable and sold separately or not, BMW doesn't. Lemfomder for bushing number 9 is OEM. I recently replaced mine, it was same as the factory installed one. You need a press, or some special driver/receiver to replace these. But you can get the arm with the bushing. Ball joint is separate piece on that arm for XI as shown in the picture. |
04-29-2015, 07:11 AM | #11 |
Rep 1,464
Drives: 2009 BMW 335xi
I would just replace both arms completely with oem/oe replacements and call it done.
04-29-2015, 01:13 PM | #12 |
Rep 166
Part number 9 in said picture is the one I linked to from strongflex.
Part number 15 in said picture goes indeed have a bushing in the end (shown in picture) that IS replaceable, but no one sells a bushing to replace it. That is the part that strongflex made custom for me, so just to be clear, the mount on the sub frame side of part 15 in my car is now polyurethane thanks to the awesome support from strongflex.
05-11-2015, 09:22 AM | #13 | |
Rep 22
05-11-2015, 12:10 PM | #14 |
Rep 166
If you grease them they wont hardly squeak. When I first installed them they did not, then in the winter when it was really cold around here (below 20 deg F) they would squeak sometimes but that has sense gone away and now they dont squeak at all.
The ride is more dependent on the shocks and struts, with the bushing you will feel in the steering wheel more response, so you'll feel the road more, but the ride its self is the same.
05-12-2015, 08:01 AM | #15 | |
Rep 22
05-13-2015, 11:53 AM | #16 | |
Rep 22
05-13-2015, 03:31 PM | #17 |
Rep 166
I havent noticed it any worse than it was before. It sure fixed my braking pulling though, and reduced my bump steer.
05-13-2015, 06:59 PM | #18 |
Rep 1,068
The bushing that can/should be upgraded is the bushing on the inner part of the tension strut. Rogue engineering has several options available for xi cars. Strongflex also has these bushings which is what I installed. The outer tension strut and front control arm use ball joints, which really don't need to be upgraded. I would just replace the entire control arm with oe part if the ball joints are worn and need to be replaced. The outer ball joint on the tension strut can be replaced with oe part without replacing the entire tension strut.
335xi
05-31-2015, 09:56 AM | #20 | |
Rep 1,340
06-17-2015, 04:05 PM | #22 | |
Rep 166
Anyways, it would have been very tempting to cut it in half, but I didnt have to..... I bought a 20 ton press. It was only 200 bucks from harbor freight as they had it on sale and I do enough work on other peoples cars I decided to get it to do the job. Really I needed it because I couldnt get the stock bushing out of the arm. I tried to use a bushing puller set and it just wouldnt budge. The 20 press was.... cranky, but under a (literally) TON of force it finally pushed the stock bushings out and then I used it to push the strongflex bushings in place, and that worked just fine. The bushings deformed while under the press to fit through the arm and then gained their shape back after being pushed all the way through. If you did somehow manage to get the stock bushing out without a press, it might be a little rough getting the bushing into place without a press, which would make it temping to cut it in half for sure.
