Car won't start
04-26-2015, 03:25 PM | #1 |
Rep 199
Car won't start
Ok folks, car all of a sudden won't start and nor will it disengage the key FOB....what gives?
07 335 E90 - MHD Stage 2+FMIC (Black)
11 X5 - MHD Stage 1+FMIC (Sapphire Black Metallic) 20 M340i X-Drive (Alpine White) |
04-26-2015, 03:37 PM | #3 |
Rep 199
Does dead battery lock the key fob in place? I bought the car a year ago and had zero starting issues so not sure if it is still original.
04-26-2015, 04:00 PM | #6 |
Rep 199
Car is at detailed while I am at home....sigh, will get a ride over and see if we can jump it. Any location tips for jump start contacts?
04-26-2015, 04:13 PM | #7 |
Rep 221
If you are going to try to jump start it don't use the contacts from the battery. Use the contacts that are in the engine bay so you don't mess up any electronics.
05-07-2015, 10:32 AM | #8 |
Rep 199
Car started and has not failed to start since then. It does however have an Electronic steering lock error that I cannot remove.....
05-07-2015, 11:07 AM | #9 |
Rep 2,189
What have you done to further troubleshoot the issue?
Have you even put a volt meter on the battery after letting it sit overnight? Did it start working again and than through wishful thinking you just left the issue hanging about and hope it went away? Its ultimately your car and your mode of transportation, help us help you.
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
05-07-2015, 05:45 PM | #10 | |
Rep 199
The electronic steering lock error was there before we jumped it and has been there since. Part of the verbiage says vehicle may not start..blah blah. So my theory is during cleaning the interior, is it possible to activate or damage the steering lock and that is the culprit? So thinking out loud in an attempt to help you help me. Thx in advance! Srb
