Now my Air Circulation (Climate Control) Is Not Working...Causes?
04-23-2015, 02:46 PM | #1 |
Rep 205
I've probably had the most hectic two weeks of my life with my e92, from error codes to injectors to fuses....I'm almost getting sick of it, almost.
So fellas have any idea why my air fans for AC or any other type of air is not on? I checked the fuses, they're okay. What am I looking at here? |
04-23-2015, 03:15 PM | #2 | |
N54 Crew
16
Rep 88
Drives: 2008 335xi 6MT
one of many threads: http://www.e90post.com/forums/showthread.php?t=536783 |
04-23-2015, 08:13 PM | #4 |
Rep 1,045
OP mentions error codes, etc. There have been documented cases of multiple error conditions suddenly being reported, and in the end the problem is a battery at the end of its life and needing replacement! Your car is 2008, it is 2015 and I would guess it is the original battery from the factory...7 years old and clearly at the end of its life!
In fact, one guy replaced his battery but did not register it. After a while all these error codes pop up...and he later reports that once he got the battery registered, all these errors went away! http://www.bimmerfest.com/forums/sho...8&postcount=32 Last edited by Wilt; 04-23-2015 at 08:25 PM.. |
04-24-2015, 12:08 PM | #5 |
Rep 965
Drives: '14 328xi sport line
Garage List 1981 Fiat 124 Spider [0.00]
2014 F30 BMW 328xi [0.00] 2006 E90 BMW 325i ( ... [0.00] 1988 Audi 90 Quattr ... [0.00] |
Plug the car into a battery tender overnight. My fan only worked on defrost in the middle of winter, and it ended up being a low battery charge.
04-29-2015, 06:56 AM | #6 |
Rep 205
Want to update you guys. It randomly started working again yesterday morning after a week of not working.
We'll see if it continues today. Wondering if this could help the diagnosis. |
04-29-2015, 12:25 PM | #8 |
Rep 137
I had this problem yesterday as a matter of fact. It stopped working a couple weeks ago and then started to work a few hours later. I thought nothing of it. It totally broke down yesterday so I went to google on it. Its a pretty easy fix at least for me it was. You just need to take the air filter cowls out. Theres a rusted screw you can see in the hole once you take the cowls out. Spray some wd-40 on it and on the bottom of the screw where the motor is (about a spoonful). Let it soak in for a minute. Go start the engine with the AC on and then go back out and use a long screwdriver or something that can reach the motor fan and start manually spinning it. Give it a few push (keep trying if it refuses to move). It took me a couple of minutes and it finally start running. All is well now! Works as new.
P.S. Does your ac lights turn on? if it does than that is the fix. If it doesnt, than I am not sure. |
04-29-2015, 12:41 PM | #10 | |
Rep 137
Heres a quick diy: P.S. Try the first method first and hopefully it will work for you. |
04-30-2015, 11:34 AM | #11 |
Rep 205
Very much appreciated dude, I hope it'll just be some some wd-40 spray for a quick fix also.
The fan started randomly working again last night on the highway and continued for the rest of the night, but it has not worked today. |
04-30-2015, 11:51 AM | #12 |
Rep 137
Do it asap. Your motor is getting worn down due to no lubricant. At least yours is moving. Mines wasnt moving at all. i had to literally jumpstart the motor for a whole minute before it decided to spin.
05-06-2015, 12:16 PM | #13 |
Rep 205
Have to give you guys another update, just in case someone else is going to have this problem in the future.
I did what Sabor said last Thursday, put WD-40 on the screw, turned the air on and it didn't work. Thought I was all but done and was in the process of calling a BMW friend of mine to get a new blower motor. But - When I was driving the fan spontaneously turned on again the next day and ever since it has been working!!! I guess the screw needed some lubrication and once the blower motor started running again, the lube corrected the issue and got deep into the problem. So for future members who have this problem, if you do what Sabor said - Don't be discouraged if it doesn't work right away. Give it some time so the Blower Motor can start itself and see where it goes from there. I've had perfect air circulation since. Thanks again to Sabor!! Saved me 120$ |
07-25-2015, 04:07 PM | #14 |
Rep 205
****Update July 2015
I know this is an old thread by now but my AC stopped working again. This time I brought it to a family friend for him to take a look at it and possibly diagnosis, 50 miles away. He took a look and he said it wasn't the blower motor fan at all, opened it up from under the passenger side and took a closer look. IDK what he did but he moved something and it started working again. Remember this a family friend but his english is not good, he tried telling me that the fan is fine but it has something to do with the wiring/harness. It get's too hot (makes sense, AC stopped working during the heat wave) and it stops responding. Now I have no idea what it means, IDK what he did but it is working now. He told me just to not but the fan on full blast and keep it low. He said fixing it would be a major headache. Does ANYONE know WTF he is talking about?!?! Lol |
