Pop noise followed by very low power
04-22-2015, 05:27 PM | #1 |
Rep 405
Hi all,
Seriously getting annoyed with the reliability of this car... Just set off after a short stop at supermarket. Engine and oil up to temperature. Floored it as I like to do now and again to enjoy the car. Got the Kick down, then a pop noise and very low power. Took it straight to Napa to ask to read codes. Drives at low rpm but no power as rpms increase. Also stalled for the first time ever when I stopped at Napa. Did I blow the turbo? No warnings or lights or anything. 335i 2011. N55 I think. Waiting in queue in napa now. Any advice appreciated. |
04-22-2015, 05:35 PM | #2 |
Rep 115
Drives: 2011 E90 335 Xdrive 6MT
Charge pipe blown off?
04-22-2015, 05:35 PM | #3 |
Rep 405
Found this that sounds similar. Hope it's something simple as they seem to say: http://www.1addicts.com/forums/showthread.php?t=641350
04-22-2015, 05:38 PM | #5 |
Rep 409
Second the charge pipe comment, that was exactly how mine broke. Although i'm surprised you don't have any codes or warnings, as my car had 4 when that happened (relating to a leak in the intake, meaning charge pipe broke).
2009 E92 335i M-Sport - MHD Stage One - BMW Performance Exhaust - BMS Oil Catch Can - CDV Delete - K&N Panel Filter - Arc Angel H8 bulbs - Gloss Black Kidney Grills - Painted Reflectors - VRSF Charge Pipe
04-22-2015, 05:42 PM | #6 |
Rep 115
I haven't had my charge pipe break yet but I would also expect some codes or warning lights. I had a light boost leak once and got the half engine light and reduced power.
04-22-2015, 05:46 PM | #7 |
Rep 405
I got a full yellow/amber service engine soon light when I started it up again. Napa didn't read codes so will probably have to wait until tomorrow morning for that
04-22-2015, 05:57 PM | #9 |
Rep 115
The charge pipe is pretty easy to uninstall and reinstall. There are DIYs in the DIY section. If that is the problem you can take the whole pipe off and check for cracks. If it's busted, I think $200 plus shipping gets you a new one. But you probably won't be able to drive the car until you install the new one. I doubt a non bmw shop will have the parts in stock (you never know) so if the charge pipe is the problem, just order a new one yourself.
04-22-2015, 06:07 PM | #11 |
Rep 405
04-22-2015, 06:09 PM | #12 |
Came to the N55 Darkside
1112
Rep 12,740
Oh man that is super rare for a stock N55 to have a blown charge pipe, but I suppose anything is possible. I hope you get it sorted man!!
04-22-2015, 06:32 PM | #13 |
Rep 2,063
Drives: 2007 335i Coupe
Garage List 1991 BMW E30 325i s ... [8.50]
1995 BMW 318Ti [0.00] 2007 BMW 335i Coupe [10.00] 1962 VW KarmanGhia [10.00] 2007 BMW Mini Cooper [9.00] |
You just POP the cherry!!!
04-22-2015, 06:48 PM | #14 |
Rep 405
Looks like you guys are right:
Will phone some places for quotes tomorrow. Would you recommend towing or trying to drive it slowly to the garage? Thanks for the help everyone |
04-22-2015, 06:53 PM | #15 | |
Rep 1,980
04-22-2015, 06:56 PM | #16 | ||
Rep 1,980
But you should be fine for the time being. You may want to consider using a metal tube now. But you'll still need a silicone connection to the throttle body. Pay no one for anything. Do everything yourself. |
04-22-2015, 06:57 PM | #17 | |
Rep 405
EDIT: Thanks - didn't see your second reply at first. Will have a look at doing that temporarily and look for the replacement part and DIYs to replace it. Cheers! Last edited by dannyjones; 04-22-2015 at 07:07 PM.. |
04-22-2015, 07:19 PM | #19 |
Rep 3,189
You can push it back on but the second you build boost it will pop off. You unfortunately lost the clip that holds it on the TB. I highly suggest an aftermarket pipe, however they do not provide a new clip. I belive there is on company that has the option to use a silicone couple and clamps. If you want stock clip you have to buy a new OEM charge pipe and then the aftermarket one. Unless you can find the clip in the bay.
04-22-2015, 07:44 PM | #20 | |
Rep 405
Definitely don't want to spend money on two charge pipes just for a simple strap/clip... :/ Is it not just a basic screwing metal strap like on the other end? Was going to have a look in Home Depot for something, just for a temporary fix as Douche advised. Will have a look on EBay anyway to see if I can find a proper clip. |
04-22-2015, 07:48 PM | #21 |
Rep 3,189
It is a C clip. You can see the slot on the pipe and the TB where it slides in. You can't just clamp it back on. I also doubt Douches "fix" will work. Not sure how much you plan to be driving it, but at most would be drive it home and wait till you get a new one.
