E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Vibrations, felt & seen in the steering wheel
      04-21-2015, 12:42 PM   #1
07chupacabra
Drives: 07 E92 335i
Car has been vibrating for a while now, I had my front control arm bushings replaced with the M3 ones due to the previous ones leaking fluid. It improved things, vibrations went from 40-60MPH to 60MPH+. I put my anti-rattle clips back on and moved a bent wheel to the rear axle, it improved things, vibrations arn't as bad anymore but still there at 65MPH+.
One thing to note, I'm running a BMW 189 Wheels square setup, 255x35x18 all around. The two wheels in the front are actually rear 189s from my friends car. I also have 5mm spacers in the front and the wheel has a hard time fitting onto the hub lip as there is very little lip left.
Also I've read that the rear wheels have a slightly larger hub mouth thing (yes horrible choice of words). Can someone clear this up?
      04-21-2015, 12:50 PM   #2
ArcticRik
Enthusiast
ArcticRik's Avatar
Drives: Arctic Metallic E90 335i
I had this issue a while ago when I put on new rims. A road force balance fixed the issue
      04-21-2015, 01:10 PM   #3
mr.335i
mr.335i's Avatar
Drives: E92 335i
I'd also recommend this. It worked for me. If that doesn't work, take it to the mechanic.
E46 325i-RIP
E92 335i- BMW PS|M3 Front Arms|FMIC|DPS|ER CP|DCI|JB4|Connect Kit|M Delete
      04-21-2015, 01:30 PM   #4
07chupacabra
Drives: 07 E92 335i
It's been balanced and aligned and no dice.
      04-21-2015, 02:11 PM   #5
5tony
Drives: '21 M5/'15 X5 35i/'88 M3
Get rid of the spacers and see if that helps.
      04-21-2015, 02:12 PM   #6
07chupacabra
Drives: 07 E92 335i
Can't the tire rubs on the coil if I do that. And I don't have access to 18x8.0 225x40x18.
      04-21-2015, 03:40 PM   #7
hockeyplayer
hockeyplayer's Avatar
Drives: 2006 325i, 2006 325xi
If you suspect the rims/spacers then can you go back temporarily to your stock setup and see if the problem persists?
      04-22-2015, 08:33 AM   #8
07chupacabra
Drives: 07 E92 335i
Bump
      04-22-2015, 05:36 PM   #9
BMV///M3
BMV///M3's Avatar
419
Drives: BMW f80 M3
Did you have them road force balanced or a regular balance? RF balance is much more thorough, allowing for a better balance.
Also try and get that bent rim taken care of, you'd be surprised how a bent wheel can affect ride quality.
      04-22-2015, 07:23 PM   #10
Agentphish
Drives: '08 328i
Could be wheel bearing too. Thats what mine was.
'08 328i | TiAg | 6MT | CDV Mod | RevMotoring Silicon Intake Tube | AG M310 | Cold | Premium | HiFi | V1 Hardwire | AirPlay - FiiO DAC
'15 Golf SE Sport | Pure White
      04-22-2015, 09:11 PM   #11
bransan
Drives: 07' e90 w/6 speed manual
Have You installed new front brake rotors? I had a customer with the same complaint, did his own brake job and then the shimmy. Found debris behind the new rotor not allowing it to seat properly. Cleaned and reattached both front rotors and the shake was gone.
      04-22-2015, 09:34 PM   #12
E90335is
Drives: 09 E90 335i M Sport
Thrust bushings?
      04-22-2015, 10:07 PM   #13
neverdone
Drives: X5, 335, Ford Lightning, 63 me
Check your bolt seating, I just had the exact same issue. Get an rf balance, then make sure those bolts are seating properly.
      04-22-2015, 10:49 PM   #14
Foxes
Foxes's Avatar
Malaysia
13
Drives: 07' E92 335i
Whilst unlikely, the possibility of a damaged tire shouldn't be ruled out.
I was on a trip down to KL last weekend and felt a strong vibration through the car, it felt like a flat tire or a loose rim wobbling off so i pulled over to take a look. Found nothing out of place and tire pressures seemed to be fine, eventually hauled her to a nearby town to get her up on a lift. Found out that I had a bubble bulging from one of the rear tires, had to get it swapped immediately. They only had a used 275/30 on hand which I had no other choice except being stranded without a tire to get me home.
I Wouldn't rule out the possibility of tires causing vibration at speeds if all other components are in check.
      04-22-2015, 11:10 PM   #15
neverdone
Oh another thing to check is your hub centric rings, make sure they are on properly, not broken, or off altogether, if you have any, that is.
      04-23-2015, 07:37 AM   #16
Bentley2012
Drives: e90 335I 6MT
I dealt with a vibration for about a year and couldn't get it solved for anything. Eventually I had all 4 wheels checked closely and it turned out every single one was bent (although some did balance). Now the car rides smooth as glass but i wish i had just done the rims the first time around. Before that i did upper and lower control arms, new tires, brakes, steering rack, and strut mounts. Money in the trash haha.
[/SIGP[SIGPIC]
// '07 / e90 / 335i / 6MT / BMS DCI / Cyba Scoops / JB4 G4 / CDV Delete / M3 upper + lower control arm upgrade / Alufelgen CS7 19x8.5F 19x9.5R /10mm F 20MM R spacers / 20% tint (windows + tails) / bavauto shift nob / matte kidney's //
      04-23-2015, 08:24 AM   #17
07chupacabra
Drives: 07 E92 335i
RRT said one has a major bend the other three are very minor and shouldn't be causing problems. They want me to get an alignment and road force balance done... because even though 2 other shops have balanced it before there are alot of weights on the car and it wasn't a road force balance.....
When I'm not getting tickets I'm busy throwing money away... feels like I'm never going to get the LSD and bumpers replaced on the car.
      04-23-2015, 08:26 AM   #18
07chupacabra
Drives: 07 E92 335i
Since I have the wheels that normally go in the rear, up front (BMW Style 189 18x8.5) is the hole bigger than the hub lip? I've heard/read that before. That could be the cause of the vibration since the wheel doesn't fit snugly onto the hub.
      04-23-2015, 08:45 AM   #19
neverdone
Oh shit, I didn't even see that part, ya you will have to check that, that would definitely be an issie, if it's not snug, you need a hub centric ring.
      04-23-2015, 08:52 AM   #20
chris82
chris82's Avatar
Drives: 128i
2009 BMW 128i  [9.80]
Soooo you have 4 bent wheels and you still don't know why you are getting vibrations at 65+ MPH?
      04-23-2015, 08:58 AM   #21
mr.335i
mr.335i's Avatar
Drives: E92 335i
Welll theres your fucking issue.
E46 325i-RIP
      04-23-2015, 09:07 AM   #22
07chupacabra
Drives: 07 E92 335i
Did you read the entire post, they said the minor ones arnt anything to worry about and the one that needs repairing is on the rear axle and since then vibrations decreased.
e90post
