A few questions about modding the N54
04-20-2015, 07:18 PM | #1 |
Rep 545
First, which plugs and gap for Stage 3 (400WHP) eventually? Typically I go a step colder per 100HP and gap the plugs down to prevent blowout. I'd expect the same with the BMW, but I don't see much info when I search for plug gapping.
Next, I was PM'd that the Big Tom style intercooler was the best design to go with. I believe that's the CX Racing design, that's very inexpensive. Is that a better choice over the VRSF 7"? I'm not interested in spending $950 for a Cobb intercooler. Just isn't gonna happen. Keep in mind, I love the car, but tend to sell them off every year. As a result, I don't want to throw more money than necessary at mods. |
04-20-2015, 07:51 PM | #2 | |
Rep 8,339
Reading your post about dragging, if you don't want to do a turbo upgrade then FBO, this includes a dual cone intake, 7" intercooler, charge pipe, catless downpipes, throw in a Cobb, juicebox, or both, then consider an LSD and subframe bushings. Also a fuel-it fuel pump will let you run e85, is fairly inexpensive, and give you big gains. Finally, if you haven't had it done have your heads walnut blasted. Hope this helps.
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
04-20-2015, 07:53 PM | #3 |
Rep 989
Stock plugs are fine like has been said before. VRSF makes some great products for a great price. The 7" will be plenty for what you are doing and the $3-400 difference won't be noticeable enough either performance wise.
04-20-2015, 08:16 PM | #4 |
Rep 1,602
NGK plugs at .022
Start with a JB4 G5, get the BT cable to backend flash and a DCI. Best bangs for your buck. Also considering adding mods to make things more reliable: - Charge pipe - Oil Catch Can Then going on to a down pipe. From there, decide between intercooler/meth/E85 with upgraded low pressure pump as your next mod. |
04-20-2015, 09:15 PM | #5 |
Rep 545
Thanks guys, but just one more question. I bought the car used with DCAI, and the previous owner wasn't the one that installed it. If I datalog boost and only see a peak of 8 psi, can I rest assured the car isn't tuned by a previous owner?
04-20-2015, 09:16 PM | #6 |
Rep 989
No...They could have taken the tuner off (be it JB4, Cobb, Standalone flash)
04-20-2015, 09:21 PM | #7 | |
Rep 545
Call me paranoid, but is it possible for a file to have been loaded on the car that datalogs as low boost when it's actually producing much more? |
04-20-2015, 09:32 PM | #8 | |
Rep 989
04-21-2015, 11:55 AM | #12 | |
BimmerPost Supporting Vendor
24199
Rep 190,807
JB4 VRSF DP VRSF FMIC / AA sport FMIC VRSF CP / ER CP BMS Intake Stock spark plugs, injectors are fine. No need to pay extra money for the upgraded ones.
04-21-2015, 07:18 PM | #13 |
Rep 545
Thanks for the info guys regarding the plugs and mods. I really do search before I ask, and I really appreciate the help.
When I get home tomorrow I'll datalog the car and see what kind of boost it's making. Hopefully its around 8PSI. Next I'll open up the ECU box and look for a JB module. I was just worried that a JB tune would lie/deceive the ecu into thinking the boost was lower than it actually was. Therefore, my datalogger would read only 8 PSI since it's reading is coming from the OBD2 port, when the actually boost might be twice as much. I checked for the JB2 signal conditioner on the charge boost sensor and didn't see one. |
04-25-2015, 09:05 PM | #14 |
Rep 545
Looks like my suspicions might have jus been confirmed. I changed the plugs today and found this add-on module in the ECU box. Anyone know what this is exactly. It's clearly tapped into the harness, so must me a signal conditioner of some sort.
04-25-2015, 10:34 PM | #15 |
Rep 545
Question was answered on another thread. Here's what it is: http://www.tf-works.com/jb2-pinout-n...5i-135i-x6-z4/
