Water Leak in passenger side footwell
04-17-2015, 03:16 PM | #1 |
Rep 145
Does anyone know if there's a fix or remedy to avoid water from coming in from the A/C vent that goes to the cabin filter. I have a leak on the passenger side footwell and is dripping from the bottow of the Blower motor unit. After carefully looking for where the water is coming from, it looks like is coming from the outside vent that leads to the cabin filter.
Also... is there a way to code or fix the A/C so it will NOT open the outside air vents. Because that would help with the leak. The A/C vent automatically opens when I turn off the A/C unit or when I turn off the car. Im in Florida and it rains often here and having that vent open is causing the water to come in Thank for you help
2008 328i MBM - Premium Package - Beige Dakota Leather - Blacklines - M219 M3 OEM Wheels - Blackout Fender Blinkers
04-18-2015, 08:20 AM | #2 |
Gateropode
329
Rep 2,848
Check the engine cowl under the hood. There is a rubber seal maybe not properly installed. Also have you removed the dead leaves from the evacuation passages @ when clogged water does overflow in that area. Coding the car is unnecessary the problem is upstream.
04-18-2015, 11:39 AM | #3 |
Rep 54
To add to Meeni's comment, it is probably the seal that runs along the bottom of the windshield and connects to the plastic cowl that you rests under the hood and over the bottom of the windshield.
I had the same problem everytime I took my car threw a car wash and took it to the dealer. They said its because someone installed an aftermarket windshield and and didn't install the seal, they just used caulking/sealant. My temporary solution was to use black duct-tape and sealed the plastic cowl to the windshield. Held up through a Canadian winter. |
04-20-2015, 10:00 AM | #4 | |
Rep 145
Thats what Im blaming it on... I've had my winshield replaced 2 years ago and it did not leak until a week ago.
04-20-2015, 10:49 AM | #5 | |
Rep 145
The area were leaves collect I keep it clean all the time... Its looks like is due to the Cowl at the botton of the winshield ($110 + tax at the dealer). Im afraid to install it myself and not make it seal properly again.
04-20-2015, 11:04 AM | #6 |
Rep 145
I removed the A/C blower motor this weekend to try to clean it and dry any water left in it (using DIY from here) and now it wont turn on.
All I did was unplug it, remove any water inside (it had a small amount of water) dry it and plug it back in. BTW... it was working right before I removed it
04-20-2015, 06:16 PM | #7 |
Rep 145
Well... Im confused. I got home and made sure that the blower motor was plug-in. And it was. So... I unplugged it and plug it back in and nothing. Then I took the blower motor out and plugged it while out of its case and it turns on just fine.... What gives. Now is working fine.
