Headlight Issue- Headlight Pointing Straight Up!
04-17-2015, 09:56 AM | #1 |
Newbie
11
Rep 84
Hey everyone, I've tried searching for headlight issues where the headlight would point straight up, but I've only found answers regarding headlights that are pointing down, due to the car hitting a pothole and the headlight "popping out of socket".
Has anyone had an issue of the headlight pointing straight up? I tried adjusting the light with the adjuster screw, but that only gives the light play. What I mean by that is at maximal height adjustment, the light is snug and in place. When I adjust the screw to lower the headlight, the headlight stays in place, but there is now play so that I can lower the headlight if I push against it. But it pops right back up if I stop pushing down on the light. Any and all help is appreciated! |
04-17-2015, 02:29 PM | #2 |
Rep 91
This post sounds like your issue, check it out:
http://www.e90post.com/forums/showthread.php?t=494479 |
04-18-2015, 10:19 AM | #3 |
Rep 1,203
The headlight on one side is aiming
downwards and the ball socket (pivot) is disconnected • Remove the rear cover and check if the ball socket (pivot) is disconnected • Reconnect the ball socket and install the additional headlight bracket to reduce the headlight |
04-18-2015, 10:22 AM | #4 |
Rep 1,023
Sounds kinda like the problem I had! This thread details the problem and fix:
http://www.e90post.com/forums/showthread.php?t=1088555
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
04-18-2015, 05:52 PM | #5 | |
Newbie
11
Rep 84
And Jwalker87, it isn't both headlights. It's just one of the lights, so I do not think it is the sensor. Thanks though! |
04-18-2015, 07:44 PM | #6 |
Rep 1,023
Ah I didn't realize that. Yeah, sounds like something mechanically wrong with the headlight itself then.
