Great amount of Oil Leaking
04-17-2015, 02:08 AM | #1 |
Pi Epsilon Pi
36
Rep 905
Okay so I have this crazy leak in the rear driver side of the car, it appears to be a thick dark substance that feels like oil, with a hint of gas smell to it.
The pictures attached was taken right in front of the rear driver side wheel. It looks like the oil is seeping from the fuel tank? Mods are only JB4, chargepipe and bov. Mileage is at 130,xxx. automatic. I don't have a jack to trace the origin of the leak, so it will have to go to the shop. Although its speculative, do you guys have any idea what it could be? Last edited by HTran; 04-17-2015 at 02:38 AM.. |
04-17-2015, 07:11 AM | #3 |
Professional Monkey Trainer
65
Rep 423
Doubt its fuel, if you have the underbody panels on the oil could be pooling on the undertrays and blowing back. I would remove those trays and check the engine for leaks.
04-17-2015, 07:15 AM | #4 |
The power of V!
99
Rep 1,971
Drives: 2007 335i coupe steptronic
Garage List 1998 Lexus Gs400 [0.00]
2010 ebony & ivory [0.00] 2006 BMW X3 [0.00] 2009 pics [0.00] 2009 e92 335 xdrive [0.00] |
oil lines to turbos or vcg
2007 335 coupe Alpine white, steptronic, sportpack, etc. (gone)
2006 X3 3.0 steptronic Titanium Silver, 2009 E92 335xdrive, next.... Caddy CTS_V! 13 Lincoln MKZ? hmmm. |
04-17-2015, 03:20 PM | #7 |
Rep 726
Valve Cover gasket maybe? Known to fail...mine did. Easy to check.
2006 Bmw 325xi VMR V715/OE lip/Redlines/Zsp Springs
1999 Eclipse Spyder Gst 16g/264cams/550cc/255lph/corbeau seats/Comp Stage 4 Clutch/ECUflash etc... |
04-19-2015, 08:43 PM | #8 |
Pi Epsilon Pi
36
Rep 905
04-19-2015, 11:29 PM | #9 |
Rep 295
04-19-2015, 11:54 PM | #10 |
DIE ANTWOORD
68
Rep 640
First get the fuel leak fixed. Easy on the pan gasket. No need to hurry. The fuel washes the oil down that has gathered on the engine (over years). A good chance the oil well is not the pan. If it's the gasket actually just re-tighten the screws first and see if the leaking stops.
King of the road says you move to slow
05-30-2015, 10:47 PM | #12 | |
Pi Epsilon Pi
36
Rep 905
