diy bmw e90 330i cigarette lighter not working, fixed. Pictures and fuse location.
04-16-2015, 07:35 PM | #1 |
Rep 76
Just figured out how to fix the cigarette lighter malfunction or just stopped working.
1 the fuse box is located in the glove department. Twist the the screws until they point up vertically. 2 locate the correct fuse location number is 30 it symbol and is in picture one. 3 the third picture show the location of the number 30 fuse which the actually 20amp and it's yellow color. 4 it in the top right second in the corner is the cigarette fuse. Pull out and inspect it to see if you have a break in the connection then replace it. 5 make sure you get a yellow 20amp that is the same size as the one you have because there are yellow that look the same in size but are not. Good luck |
