F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > Warning: Battery Cover Removal
GetBMWParts
      04-15-2015, 05:44 PM   #1
Mike_L
Drives: 2015 335xi GT M-Sport MPPK
When removing the battery cover or accessing the manual fuel door release, you must pry the panel up from the outside, behind the net. If you pry from the inside, next to the luggage rails, you will break the 2 tabs holding it down. Guess how I know.
If you break it, the part number is 51477325510, and MSRP is $27.35 as of today. It can be had for $21 and change from ECS or most wholesale dealers.
On a side note, to actually get to the battery terminals, you also have to remove the whole right side rear panel. I have no details on that yet, haven't done it. I'll add to this thread when I do.
      04-15-2015, 09:07 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Why are you trying to access the battery?
      04-15-2015, 09:26 PM   #3
Mike_L
Gotta pull the negative cable for my JB4 install.
      04-16-2015, 02:04 PM   #4
Mike_L
Still didn't pull the battery, but did take a few pics.
First, this is the result when you remove it the wrong way. Broken tabs.
Second, this is what you see when you remove the cover. The green thing is the manual gas tank release.
I have no idea how to get those pins out for battery access. They aren't standard pushpins where the center goes in and out. I think they may be plastic rivets. Already emailed Burger to see if theres a way to disconnect the battery from the fusebox or somewhere else, cause I'm not getting those out..
f30post
