Car broke down for first time. How much should I expect?
04-15-2015, 06:05 AM | #1 |
Rep 376
2008 e92 328i 92k miles.
Car drove fine until I tried to start it back up at hospital parking lot. I'm getting humming noise(guessing fuel pump?) all lights work No error code from BMWhat No crank I'm guessing starter is out. How much should I expect? |
04-15-2015, 09:40 AM | #2 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
Battery. $250 plus $100 labor for install and register.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
04-15-2015, 10:10 AM | #3 |
Rep 1,045
I have seen reference to a $650-1200 starter job from E9x owners in Northeastern US. But since you are in Korea, you really need to get quotes in your part of the world!
Enough battery to light the lights is NOT necessarily enough battery to run the starter! Your car is old enough that it might have the original battery, which has run to the end of its 5-7 year life seen in most cars. |
04-15-2015, 10:01 PM | #9 | |
Rep 2,793
04-16-2015, 03:05 AM | #11 |
Rep 376
Indy is replacing starter motor for 480 labor included. Im doing all the maintenance my self(transmission fluid, diff fluid, oil, pads etc). Stationed in korea right now and parts are 2x than states. Takes about 2 weeks to get parts from states if i want to do it my self. Starter motor is 270(rebuilt). So about 210 for labor.
I did research for diy on starter and it seems its pia to replace it. Last edited by techie182; 04-16-2015 at 03:26 AM.. |
04-16-2015, 11:50 AM | #12 | |
Rep 1,045
DIY is great...when DIY is 'done properly' |
04-28-2015, 11:12 PM | #13 |
Rep 596
What was the hard part of doing the battery replacement? Also, which brand and group/size did you get?
2007 BMW 335i, 2014 Audi A4, 2016 Acura MDX
Join us on Facebook: E90Post - Houston Houston BMW DIY Services |
04-29-2015, 06:58 PM | #14 |
Rep 376
They gave me discount for paying cash.
Paid $450 total for Bosch starter and labor. Plan to order Water Pump/Tstat from states. Damn thing cost $700 here. $350-$400 in U.S. Labor should be around $200. Labor is cheaper here but damn parts are expensive. Also plan to replace battery myself and code using BMWhat. |
04-29-2015, 07:17 PM | #15 | |
1821
Rep 5,337
05-01-2015, 01:26 PM | #16 |
Rep 1,045
Perhaps the failure to register the battery had NOTHING to do with alternator failure. The VOLTAGE regulator causes the alternator output be within a certain range, but the IBS regulates charging so you don't wear out your alternator prematurely. Either VR or IBS might have caused an issue. In your parent case, it was likely the VR which caused alternator failure, and you automatically get a new VR on the new alternator I believe.
05-01-2015, 01:46 PM | #17 | |
1821
Rep 5,337
The problem was it didn't show up right away. Car worked fine. No dash warnings. 18 months into the "new" battery the car needs to be jumped and we found out that saving a few hundred bucks ended up costing a new alternator.
