Oil filter housing cap is stuck?
04-13-2015, 07:21 PM | #1 |
Rep 796
When i had an oil leak im assuming after they changed the oil and stuff they over torqued the oil filter cap because from the looks of it it looks like its seized on the thing if it makes sense
04-13-2015, 07:22 PM | #2 |
Rep 796
Im using a torque wrench to take it out but it keeps slipping its starting to smoothe out instead of having its corners which sucks cause i need to drive but i drained all my oil hoping to change it today
04-13-2015, 07:44 PM | #4 | |
Rep 796
04-13-2015, 07:50 PM | #5 |
Rep 1,980
No panic.
Either put a thin towel over the cap to get grip with that wrench or go get a oil filter Plier or band. Try the thin towel (paper or fabric, or sand paper works too) over the cap first. That will make the wrench fit snug. If none of that works, replace the drain plug and fill it with oil, change the filter some other time. |
04-13-2015, 07:51 PM | #6 | |
Rep 796
04-13-2015, 07:54 PM | #8 | ||
Rep 1,980
But definitely try paper towel or sand paper first. Sand paper works even without the wrench, with the bare hand. |
04-13-2015, 07:55 PM | #9 |
Professional Monkey Trainer
65
Rep 423
Well ideally you want to change it out but if you leave it in one more oil change it won't explode, but if you can replace it. If it becomes too clogged and/or dirty it could starve your engine for oil.
JB4 G5 ISO / ER Charge Pipe and Tial BOV / Wagner FMIC / CYBA Tips & Air Scoops / AFE DCI / BMW PE Exhaust Mod / M3 Rep Bumper / Dynavin E9x
04-13-2015, 07:55 PM | #10 | |||
Rep 796
04-13-2015, 08:25 PM | #11 |
Rep 268
When you are removing make sure you don't put constant pressure\force on it or you will break something . strong jerking pulls (hope this makes sense ) this will break it lose ... Good luck
04-14-2015, 01:41 AM | #13 | |
Rep 2,108
04-14-2015, 03:31 AM | #14 | ||
Rep 796
04-14-2015, 05:13 AM | #15 |
Rep 18,737
Righty - tighty
Lefty - Loosey
04-14-2015, 05:38 AM | #16 |
DIE ANTWOORD
68
Rep 640
You can make your own tool. All you need is a bicycle chain (~32 links) and a cheap wrench socket (eg for a mopped spark plug). Infeed the chain into the hole that's for the breaker bar and close it with a locking link. That tool wont let you down not even on smoothed out surfaces The pics give you an impression
King of the road says you move to slow
04-14-2015, 07:26 AM | #17 | ||
Rep 1,980
04-14-2015, 10:31 PM | #18 | ||
Rep 1,073
04-14-2015, 10:34 PM | #21 | ||
Rep 796
04-14-2015, 10:34 PM | #22 | |||
Rep 1,980
