Noob here
04-12-2015, 03:01 AM | #3 |
Ez tur90
189
Rep 3,191
Would recommend doing research. That way you get an idea of how to get the most from the tune.
Install is easy, plug and play. Watch the tutorial and it'll give you step by step instructions on how to install. If you're stock, run maps 1 & 5.
04-12-2015, 08:58 AM | #4 |
Rep 319
Just take your time and do everything slowly and meticulously. No reason to rush through it and ruin something what's going to cost you a lot more in the long run.
It's pretty straight forward though, read the instructions a few times and watch the youtube video before installing just so you have an idea of how things are going to be. I just did mine a few weeks ago and it was pretty easy, just took my time and loved it afterwards! |
04-12-2015, 09:09 AM | #5 |
Rep 79
As of right now yes stock, but planning to get downpipe soon. And one more question comes to BOV do I have to upgrade that too or just leave it stock. By the way the car is a 335i sports shifter
04-12-2015, 09:45 AM | #6 |
Rep 11,903
Welcome to the forum
Sounds like you have done some research seeing you are installing JB4 etc FYI you may need to change spark plugs, coils and replace the stock plastic charge pipe with an aftermarket charge pipe. The JB4 tune puts strain on the ignition system which can lead to misfires etc if your spark plugs and coils are old, the extra boost can cause the plastic stock charge pipe to fail or the diverter valves to leak (and you dont want bits of plastic charge pipe in your turbos) Good luck with the install...... |
04-12-2015, 10:28 AM | #8 |
Rep 281
take pictures of everything while you are taking it apart, just in case you cant figure it out and need to put it back to stock. like the others said its easy.
04-12-2015, 10:44 AM | #9 | |
Rep 79
04-15-2015, 08:52 PM | #14 |
Rep 79
Finally install my jb4 and I did all by myself. It wasn't so bad. Lol. But am enjoying it but I think I need to replace my plugs because my maintenance engine soon came on and the car misfired. Thanks guys.
Now I heard that you can adjust ur exhaust with jb4 is this right or wrong? |
04-16-2015, 12:32 PM | #15 |
BimmerPost Supporting Vendor
24199
Rep 190,807
take your time , follow the installation guide step by step and do not force install anything. If it is not plugging then your are doing it incorrectly.
04-16-2015, 12:36 PM | #16 |
Rep 1,869
Its pretty intimidating at first. JUST DONT BREAK ANY CONNECTORS IN THE ECU BOX! Take your time for sure.
Haha once you do it once, it becomes pretty routine. |
04-16-2015, 01:39 PM | #17 | |
Rep 2,014
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
04-16-2015, 01:46 PM | #18 | |
Rep 2,136
Put the Speedo on 10/Tach on 1 to read the codes so you know exactly why your check engine light came on... Print these two sheets and keep them in your car...
JB4 G5 w/ Backend flash - Walbro 450lpfp - VRSF DPs - VRSF 5" stepped IC - DCI - ER CP w/ Tial BOV - 335is clutch Last edited by Gizm0; 04-16-2015 at 01:54 PM.. |
04-16-2015, 02:12 PM | #19 |
Rep 10,120
Get the charge pipe asap. The stock one is pretty weak and will snap on you soon. Takes about 40min to swap the charge pipe for a first time DYI.
04-16-2015, 02:14 PM | #20 |
24199
Rep 190,807
+1 000 000
04-17-2015, 04:40 PM | #21 | |
Rep 79
