Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      03-21-2015, 10:16 AM   #1
Cristov9000
Drives:
Mirror Folding coding
I was playing around with coding but I couldnt get the car to do what I wanted it to do. I am trying to get the mirrors to unfold immediately when the car is unlocked via the fob or comfort access. I also dont want the mirrors to fold with the fob or CA, I would like to have to put them in manually. However, I wouldnt be opposed to having the mirrors fold after holding down the fob button if that was a requirement.
Here is what I coded:
3053 - KOMFORTSCHLIESSUNG_FB = aktiv 00
3053 - KOMFORT_SCHLIESSEN - WERTE = 0F... I also tried 00
3110 - ASP_BEIKLAPPEN = aktiv (this as like this from the factory)
3110 - ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN = aktiv
Am I missing soemthing?
I also coded the euro anti-dazzle LED headlights but I like in a city where I think the car thinks it is too bright to activate them. Is there a way to tell they are working or coded correctly without guessing if the car thinks its dark enough and working?
Thanks in advance
'86 325es M-Technik1 s54b32TU 6-speed
'89 325is m20b25 5-speed
'15 M4 MPerformance s55b30 6-speed
      03-21-2015, 03:16 PM   #2
gtrsam
Drives: 2015 m3
also having trouble with this. everything else I coded worked except this.
edit nm got mine to work by holding down lock using those values
      03-24-2015, 10:30 AM   #3
Cristov9000
Drives:
Do they work on folding out as well?
Anyone know if you can just have them fold out with CA and not fold in?
      03-24-2015, 11:57 AM   #4
gtrsam
Drives: 2015 m3
folding in you have to hold ca or key fob lock. folding out only have to press once
      03-25-2015, 01:00 PM   #5
Cristov9000
Drives:
Do you have to fold the mirrors in via CA or fab to have them fold out via CA?
Mine will not fold out... but then I didn't use the code to get them to fold in via fob
      03-25-2015, 02:10 PM   #6
gtrsam
Drives: 2015 m3
fold in/out with both fob or ca
      03-25-2015, 03:12 PM   #7
heckyeahbro69
heckyeahbro69's Avatar
518
Drives: m3
ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN set this to active
      03-25-2015, 09:01 PM   #8
TwinTurbs
Drives: F80
My mirrors unfold upon unlocking, but only if they were folded in by holding the lock button on the fob. However, if I fold the mirrors via the button on the door panel, they do not unfold when unlocking.
Here's what I changed:
FEM_BODY 3053 KOMFORTSCHLIESSUNG_FB
FEM_BODY 3110 ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN
FEM_BODY 3110 ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN
All set to aktiv
      03-26-2015, 09:00 AM   #9
Cristov9000
Drives:
Ugg... that's exactly what I didn't want to hear. Thanks for the info though.
      03-26-2015, 09:29 PM   #10
M4LAKA
Drives: 2022 M5 Comp
What does ca stand for
      03-27-2015, 06:21 PM   #11
gtrsam
Drives: 2015 m3
comfort access. the sensor on your door handle
      03-27-2015, 11:17 PM   #12
Mr. Hankey
Christmas Poo
Mr. Hankey's Avatar
1017
Drives: Incoming G87
I can confirm also that if you fold mirrors manually from the door panel before you leave the car they won't unfold automatically when you unlock. If I fold the mirrors with the key fob then they will automatically unfold when I unlock with key fob. You can also code a speed at which they automatically unfold if you don't want to touch the key fob to unfold...set it to 1. when the car moves they unfold.
      04-12-2015, 03:55 PM   #13
Pauly Walnuts
Pauly Walnuts's Avatar
26
Drives: M4
I'm having issues with this too. Everything coded like previously mention but when I press the CA on the door or the keyfob the mirrors still don't fold in or out.
      04-12-2015, 06:45 PM   #14
IMrMark
IMrMark's Avatar
Drives: 2015 BMW M4
2015 BMW M4  [9.66]
Can you confirm your values via screenshot? Haven't had an issue with this yet personally, so curious to see what might be going on.
2015 ///M4 F82
[ Mineral Grey | SO Ext | 19" Black | 6MT | CFRP Interior | LED | Executive | Side/Top Cameras | Adaptive M Suspension | HK Surround ]
:: will code locally for rum, beer, or chicken; PM as desired ::
Instagram: IMrMark
      04-12-2015, 07:23 PM   #15
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
Are you pressing and holding the button down for 15 seconds?
If that works, then code KOMFORT_SCHLIESSEN = Werte=01 to change it to a 1 Second delay.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      04-12-2015, 10:20 PM   #16
Pauly Walnuts
26
Drives: M4
Shawn, I don't know how you have all the answers but I really appreciate it man. Works like a charm now! Thanks again, for the 50th time
      04-12-2015, 10:27 PM   #17
shawnsheridan
      05-03-2015, 05:35 PM   #18
///F80M3
///F80M3's Avatar
Drives: 16 AW M3
Do you have to hold the lock button for the mirrors to fold or just press once?
      05-03-2015, 06:39 PM   #19
shawnsheridan
You have to press and hold for as long as the duration defined in FEM_BODY => KOMFORT_SCHLIESSEN.
      05-03-2015, 07:53 PM   #20
///F80M3
///F80M3's Avatar
Drives: 16 AW M3
ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = aktiv (werte = 01)
werte = 01 Meaning 1 second?
      05-03-2015, 08:38 PM   #21
shawnsheridan
No. It is written above. Werte 01 = aktiv. This is not a timing function. It is toggled between enabled and disabled states.
      11-23-2015, 12:34 PM   #22
G4BR13L
G4BR13L's Avatar
Belgium
523
Drives: BMW M4
I have set it to 01 but I still have to press the sensor on the door handle (comfort access) for like 3 seconds for the mirrors to fold. The same with the key FOB.
Unlocking the car using either comfort access or the key FOB immediately unfolds the mirrors which is perfect.
Can someone tell me how I can have the mirrors fold immediately?
f80post
