Does frigid cold weather cause limp modes?
01-24-2008, 09:52 PM | #1 |
Rep 1,738
Im just curious because I am running V2 with the latest map and I notice that I have been getting limp modes in higher gears esp. 3-4th. Im wondering if cold weather puts more load on the engine since Boost is not the only factor for engine load. In chicago its very cold, right now its -5F! not that I am going to push my car in this weather but I do when the roads are clean and its in the upper 20's or 30's and thats when i had the limp modes and SES lights.
01-24-2008, 10:36 PM | #2 |
King Kong
59
Rep 771
It's pretty cold here and I haven't had any yet, thank god.
08 E92 M3 - AA ECU, AA Pulleys, AA Air Filter, AA Short Shifter - CURRENT
E92 335i - Vishnu V3, Exhaust, Intake, BOV, CDV Delete - SOLD 1991 850i Dinan Twin Turbo - SOLD |
01-24-2008, 10:49 PM | #3 |
Rep 18
It was -10. Waited for the car to warm up (as much as it possibly could at that temp) and it threw limp codes in 3rd and 4th. Not pushing it too hard either. Guess V2 is pretty picky at these cold temps.
When close to zero or below, I've just been keeping stock map and that keeps things under control. |
01-24-2008, 11:02 PM | #5 |
Rep 4,484
Chitown,
If I remember correctly you said you were getting these limp modes at or near redline right? If so, hook up your computer and at 6500 rpms and 7000 rpms lower your user torque settings by .5% (or whatever it rounds too). So if you are at 93.1xxx% at 6500 and 7000 rpms, punch in 92.4% (and it will round to the appropriate amount) and see if that solves the issue. |
01-24-2008, 11:11 PM | #6 | |
Rep 1,738
I have done that, same issue. |
01-25-2008, 12:28 AM | #7 |
Rep 771
Drives: LBB M2C, VO 1M, GSA 1200
Garage List 2021 BMW X3M Compet ... [0.00]
2019 BMW S1000R [0.00] 2019 M2 Competition [0.00] 2018 BMW 1200 GSA [0.00] 2011 1M Coupe [9.75] |
I would be very curious to hear Shiv's response to this.
I'm waiting until the end of winter to add a piggyback to avoid this very type of behavior. I've run my stock car at -36F ambient temperature, and I suspect the stock ECU is dampening boost substantially when it gets very cold. Once the ambient temperature gets back to -10F or warmer, performance seems to return to normal. Is there a certain ambient temperature at which significant pressurization of the air charge is deemed excessive by the ECU? This is my first FI vehicle, and more knowledgeable input would be welcome. |
01-25-2008, 07:05 AM | #8 |
Rep 5,780
01-25-2008, 07:56 AM | #9 |
Rep 1,738
I took them down to 85% same issue, going to try 80% tonight if weather/road conditions permit me to push my car up to 100mph temp tonight is supposed to be about -2F
01-25-2008, 08:07 AM | #10 |
Rep 5,780
01-25-2008, 08:39 AM | #11 |
Rep 1,738
02-21-2008, 09:50 AM | #13 |
Rep 954
Drives: 2008 AW 335xi
dont fool yourself, cold weather should help the car. They actually make more power when's its colder. Also out here you will run your fastest track times in the spring and fall when its cooler. The vette runs like a beast with the blower in this weather. Just can't get traction. +1 hotrod182
Dont Believe me put the car in the dyno now and again in the summer. Since its so cold here the cars dont have to work as hard to stay cool. Literally this weather is like a mini nos shot. |
02-21-2008, 09:53 AM | #14 |
Rep 954
I still stand by what I told you yesterday. Get into limp, take procede out and go to the dealership. Let them take a took and fix if need be and then hook it back up. Its def not the weather causing this though.
02-21-2008, 10:04 AM | #15 |
Rep 954
dont know where you get -5 and -2 from. Last night was +15 and tonights low is +18. Definately should not go limp in this.. Its not that cold.
02-21-2008, 10:34 AM | #16 |
Rep 1,738
Nick, the post was on the night of JANUARY 25th. it was -2 degees out that night. looking forward to tonights run. Forgot to update the firmware and up the tq values. so should be a bit different. we'll see what happens.
02-21-2008, 10:39 AM | #17 |
Rep 954
ahhh makes sense. I was like wtf is I'd talking about? LOL I work until 930 so I'll call when I get off.
02-21-2008, 10:13 PM | #19 | |
Rep 954
02-21-2008, 10:22 PM | #20 | |
Rep 6,608
I install all tunes, intakes, o2 simms, and most cosmetic mods. PM me for a quote. |
02-23-2008, 10:34 PM | #21 | |
Rep 1,948
Has your car been sorted out now? I'm having the same issue here. Not so much cold weather but if I drive around, 1st, 2nd, 3rd, are great. Tons of power. I'm using the 12/29 map. If i push it hard and do a 2nd, 3rd, 4th pull letting the car shift, i will randomly get a limp on 3rd/ 4th. I was out logging yesterday and great! Today, WHAM. limp mode.... |
02-23-2008, 10:54 PM | #22 |
Rep 496
i have a booost gauge and notice i only 12-13psi on days below 20 F. When it warms up above 40-50 the car feels like it runs much better and consistently hits 14-15psi. I thought turbo cars do run more effeciently in the winter, but doesnt necesseraly make them faster. I figured youd make the same hp on a 0-20 F day at 13psi as you wold on a day that was 50F at 15psi. This is what i thought im prob. wrong though. I can understand how an 80F day is not gonna help though. I think 40-50 these cars run their best.
Manny : 2008 335xi sedan : SG, Terra, Alum, 6mt, SPP, PP, 162s Mods; Procede V4 | Remus Quads | UR catless dps | H&R coilovers | Modified CDV | Injen Intake | Spearco IC | Forge DVs | Defi Boost Gauge w/controller | Vorsteiner CF Hood + Front Lip | OEM M-tech Body kit | Hamann eyelids | Predator Ice Angels | 19" Volk Progressive Me's | Rotora BBK | 18" Rota Torques w/Blizzaks |
