02-22-2015, 08:44 AM | #1 |
Rep 468
Ignition Coils part of Preventative Maintenance?
Just curious to see if anyone replaces their ignition coils on a preventative basis...or does everyone tend to wait until they have a fault? Am replacing spark plugs soon (2009 E92 M3 with 65k miles) and want to get a feel for what the experience has been on the forum.
02-22-2015, 11:16 AM | #3 | |
Grown Azz Man
429
Rep 3,021
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
02-22-2015, 11:16 AM | #4 |
Rep 4,381
Doesn't seem like a common problem...although one persons UK engine failure was attributed to a failed coil detonating the crap out of that cylinder including the rod bearing.
I would hope though that you would be able to hear and feel if a coil had failed and your engine was pinging. |
02-22-2015, 11:25 AM | #5 | |
Grown Azz Man
429
Rep 3,021
02-22-2015, 02:11 PM | #7 |
Rep 5,484
Coils, no matter who makes them, do lose some power over time from heat and cycles, and the older they are the less they can hold up to long periods of high load, but it's not likely to cause much of a problem on a street car. IIRC the guys runing these cars in Grand Am weren't replacing coils very often, or at all, it was one of the questions I asked in the pits. I'm replacing mine at 75k but I'm going to keep the used ones as known good spares. I doubt they're appreciably worse than new but I'm going to be doing plugs anyway and it takes no extra time at all to put new ones in (plus I'm likely to break at least one getting them out because I'm a hack). I've no doubt they'd likely all make it for a long time, but I'm one of those guys whose M3 has been so reliable he's having to hunt for things to spend the "M cars need lots of maintenance" budget on...
These cars are pretty good about yelling at you when a coil is starting to go bad, it will throw a cylinder-specific code. The only real driveline "repair" my car has had in 68,000 miles was a #5 coil replaced under the factory warranty. No symptoms, car ran fine, but when it was pulled it had started to swell Somebody did a study on GM's LS3 coils (popular retrofit) and found they tend to fall off after a certain amount of time in service.
02-22-2015, 02:32 PM | #8 |
Grown Azz Man
429
Rep 3,021
+1.....got the old ones on standby....................Phil
