2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) Winter Car Care Tips - Salt Removal
      02-21-2015, 10:00 AM   #1
Detailers Domain
Detailers Domain's Avatar
Drives: 20 M2C / 22 X3MC
Winter Car Care Tips - Salt Removal Wash
Helpful Winter Tips
  • Keeping your vehicle as clean as possible during the winter will go a long way to cut down the damage done by salt and sand.
  • Take your vehicle to the car wash as often as possible. If you can get to your undercarriage as well that would be a plus.
  • Make sure to protect your car with your favorite wax or sealant.
Make sure the car is completely dry
  • Carefully dry the edges of the doors inside and out, including the undersides of door handles, all hinges, plus the hood and trunk edges. This helps keep them from freezing shut.
  • Use a good quality spray protectant on all exterior rubber or vinyl surfaces. It may be best to spray they applicator you are using instead of spraying the product directly onto the surface. This will avoid any overspray onto the paint.
This BMW 435 X Drive receives a salt removal wash and protect.
Salt Removal - Wash and Protect
Our special pre-soak was designed to chemically remove the majority of the salt and road grime off the paint, with our touch less approach we are preserving the condition of the paint.
After shot
Porsche Cayenne Turbo - Mats - Salt Removal - just as important make sure your interior is free and clear of salt as it will cause long term damage to your interior bits and pieces.
Before
After
      02-21-2015, 09:04 PM   #2
NEUE02
NEUE02's Avatar
267
Drives: M235i
So the results were achieved with only a rinse and no mitt or towel work?
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S
      02-21-2015, 09:17 PM   #3
Detailers Domain
there was a traditional wash done after the pre soak. the key to our salt removal jobs is the less you touch it the less you put anything back into it. so we took as much salt and grime as we could during the pre soak and followed with a traditional 2 bucket wash.
      02-21-2015, 10:22 PM   #4
NEUE02
NEUE02's Avatar
267
Drives: M235i
Makes sense. Thanks for the clarification.
The Stable
      02-21-2015, 10:59 PM   #5
Detailers Domain
no problem at all. always here to help.
      02-21-2015, 11:07 PM   #6
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
Helpful Winter Tips
After shot
Interior Mats - Salt Removal - just as important make sure your interior is free and clear of salt as it will cause long term damage to your interior bits and pieces.
Before
After
why does a bmw have Porsche mats?
      02-21-2015, 11:39 PM   #7
Detailers Domain
I'm just showing you photos of salt removal on the outside and inside of the car.
Didn't mean to confuse you.
      02-22-2015, 12:31 AM   #8
pikcachu
pikcachu's Avatar
1399
It's all good... thanks for the tips
What are those brown horizontal lines on the clean matts ?
      02-22-2015, 12:58 PM   #9
Detailers Domain
      02-23-2015, 10:25 AM   #10
NEUE02
NEUE02's Avatar
267
Drives: M235i
Vacuum lines.
The Stable
      02-23-2015, 10:50 AM   #11
Detailers Domain
thanks for answering that
2addicts
