do the xenons motors have a fuse? (e92)
02-17-2015, 01:13 PM | #4 |
Rep 81
I have checked the mechanical arms. they look connected and don't look bent or anything. "auto setting" is this a setting on the Idrive? I just turn the lights knob two clicks to the right.
02-17-2015, 01:15 PM | #6 |
Rep 2,136
02-17-2015, 01:30 PM | #8 |
DIE ANTWOORD
68
Rep 640
The xenons always do a self leveling routine after start. The motors have no extra fuse. They (stepper type) can go bad but if both refuse to work it's likely to be a fault of the light module (which is the footwell module on our e9x's but I'm not sure)
Check for codes.
King of the road says you move to slow
02-17-2015, 01:32 PM | #9 |
Rep 2,136
02-17-2015, 01:52 PM | #11 |
Rep 81
not sure if I have the xenon's that go left and right when I steer. the car has recently been on a ramp though having the DPF delete performed.
below is the pictures of the xenon control arms as they sit. could they be in the wrong position? http://s1383.photobucket.com/user/mi...jgkn6.jpg.html http://s1383.photobucket.com/user/mi...subkb.jpg.html no faults that relate to lights when I did a code read with a code reader either. |
02-17-2015, 03:26 PM | #12 |
Rep 81
is the front xenon control arm bracket bent?
so after some reading on the net. someone else had a similar issue. the garage had damaged his front sensor causing the xenons to point low. on further inspection is my bracket bent? it looks to be bent towards the centre of the car.
I have attached a picture from the side and below. can anyone confirm if bracket bent and if so what the original position should be. im hoping the bracket should be a right angle. from the back 4_zpsccrfmyjx.jpg[/url] and from underneath |
