Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      02-15-2015, 02:16 PM   #1
Mandi90TT
Drives: BSM 6MT M4 F82
A/C and Climate Control System not on when Starting Car..
So, all of a sudden, one day, when I turn on the the car, the climate control system is no longer on, and I have to press the auto button to start it. This is not just the A/C or blower, or one component, it is the entire climate control system that just isn't on when I start the car.
This happened one day out of the blue; not after I did any coding, or anything like that, it just happened.
Any ideas?
I've gone into the ECU via E-SYS and made sure that the settings for A/C remember last setting is activ and all that.
2015 Black Sapphire Metallic 6MT M4
      02-15-2015, 02:38 PM   #2
ciaranob
ciaranob's Avatar
Drives: M4 Convertible
Any ideas?
I wonder if there is another module to code the info as on (btw, I have this as std in mine as being a Vert I actually prefer everything to be off on start-up as with roof down it is of course not needed )
Seemed like when I got my car coded by Shawn Sheridan, that most functions required tagging the same item in 2-3 modules in E-SYS - but I am no expert. The other odd thing that we experienced was that for the life of us we (more correctly he!) could not get the coding to have the mirrors to fold automatically when remote locking the car to work - tried numerous approaches and again had to hunt down more than one location in the coding to change. We decided to leave it as is and sure enough, when I got home, shut the system does one more time and re-started everything up and lo and behold it worked!! Almost as though the software needed a multiple reboot to take the new coding as std. Again this is not very helpful but does seem like your issue would most probably be related to prior coding and any recent alterations you made in E-SYS?
Apologies fro rambling!!
Individual M4 Convertible ED Sept 2014
      02-16-2015, 03:02 PM   #3
Mandi90TT
Anyone have any ideas on this?
      02-19-2015, 05:14 PM   #4
Mandi90TT
Bump for any answers?
      02-21-2015, 08:10 PM   #5
SIN_CITY_TROLL
Livin the Dream!
SIN_CITY_TROLL's Avatar
Drives: EVERYTHING
Any ideas?
my best guess is he did this code to turn of the memory... after its coded, it usually take a while for it to go through...
IHKA 3002 MEMORY_OFF aktiv nicht_aktiv Air Conditioning will remember if ‘Off’ or ‘On’ from previous shutdown.
"Always Love The Hate"
      02-21-2015, 08:20 PM   #6
Mandi90TT
I don't think I changed that, but I can check. So we're clear, I should set that to nicht_aktiv to make it remember the setting each time?
      02-21-2015, 08:32 PM   #7
SIN_CITY_TROLL
Livin the Dream!
Drives: EVERYTHING
It should be "aktiv" so that it remembers from previous shut down.
      02-21-2015, 10:22 PM   #8
Longbow64
_______
Longbow64's Avatar
169
Drives: 15 M3, 13 X3 35i MSport
I'll check mine next time I'm in there but when I bought my car used with coding already done, the AC was off every time and it drove me nuts. I went in there and changed the line. I believe they had it set to aktiv which drove me crazy.
This line is kind of like a double negative. It's titled MEMORY_OFF so you want it not active so memory is on.
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat
      02-22-2015, 10:12 PM   #9
Mandi90TT
Yep, that was exactly it. For some reason, I must have changed it to aktiv when I did some coding, but it took awhile for it to take effect. I went in tonight and changed it back to nicht_aktiv and immediately the blower came on (once I coded and saved the fdl, that is), which is what I had it on last time I drove the car. So, things should be fixed now.
Thanks, everyone
      02-22-2015, 10:13 PM   #10
Longbow64
_______
Longbow64's Avatar
169
Thanks, everyone
It's like that on one of the commonly used cheat sheets. I had to look at it twice too.
f80post
