02-01-2015, 07:11 PM | #1 |
Rep 205
320i ER Downpipe does NOT fit
So installed the ER downpipe today, and it took me very long time because the ER DP and original cat is not the same diameter where it leads to the exhaust.
I think they should tell the costumer this so you could be prepared when installing. This is not a easy install when you have to use welding, angle grinder and such to barely fit it together. I'm disappointed ER! So how does it sound? I got no fucking idea. I have too much leakage from the fuckup fitment I tried fix which I did not have very much success with. I hope it will become less noisy when leakage have been fixed. Right now I find it embarrassing to press the accelerator. Performance gain? I would think so, don't know how much but feels like turbo is spooling up much faster. Didn't get any CEL or codes. But I guess that is thanks to the JB4.
320i Activeflex - JB4 - Afe Airfilter - VRSF IC - ER DP - ER CP - @Ethanol
02-01-2015, 07:44 PM | #2 |
e92 - 335i
179
Rep 743
I have many products from ER and all of them have been top quality units with great fitment. Customer service is wonderful, Fred is an outstanding business man.
Did you measure the pipe size? I had to expand the exhaust piping ever so slightly using a pipe expander to get that nice slip fit. This is not a manufacturing issue from ER. Did you get the catless version? If so, be prepared that 50ish seconds on a cold start you will get the sound of a leak but will go away. This is not a leak. See my exhaust post for a sound clip. I think this is caused from one of two things or a combination of both. 1 - With a catless version there is more turbulence in the DP when exhaust gases are cold. 2 - There is now a bottleneck as the DP is now 3" and the exhaust is also 3" but the connection is only 2.5". I will be getting this bottleneck removed and will be able to make the determination on being true or not. Have you contacted ER? The professional thing would be to make contact with them first before trying to throw them under the bus. Major leaks as you are describing is not going to go away from carbon build up, a small leak might though. |
02-01-2015, 08:08 PM | #3 |
Rep 5,316
Drives: G80 M3 6MT
You could have just gotten the wrong one, I remember something about there being a different version for different piping sizes.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
02-02-2015, 12:26 AM | #4 |
Rep 205
I believe there is only one type for the N20.
I got the catless DP and there is no way in hell that is going to fit. Didn't need to measure it to figure that out when trying to fit it. Yes maybe a pipe expander could do the trick? But who has this kind of tools laying around a home? I know of another guy who had the same problem, but I hoped this issue had been corrected since he bought his, but it turned out to be the exact same thing. Now I will take my car in to a workshop and have them figure out how to fix it. I just hope I don't need to take of the DP from the turbo which is time consuming and hard to do IMO. I will agree that at cold start it is exceptional loud and becomes better after a minute or two. But that doesn't fix the leaking poor fitment I had to make.
02-02-2015, 01:18 AM | #5 |
Rep 61
Im surprised you have this issue.
I say this because i bought one back in 2012 when it was first released. The product was shit. The ER downpipe diameter was too small and the pipe too short. i installed it anyway because the workshop was already charging labour and i didnt want to hassle a return of the product. Regretted that decision because a few days later the exhaust was rattling like crazy because the downpipe is too short and doesn't connect properly,. So i sent it back to ER but they wouldnt refund a cent because the product is "used" So far the reviews of the ER chargepipe and intercooler are very sketchy on fitment as well. Take this as a lesson learned as i did. Stay far far away from Evolution Racewerks products |
02-02-2015, 08:48 AM | #6 | |
e92 - 335i
179
Rep 743
I stand behind all my ER products and will back ER as a great company to work with that sells quality products. I also have the ER CP and IC, both fit great with "0" issues during install. I have posted reviews for most the installs I have done. To each there own. Everyone has there opinion. Sorry ER hasn't provided you satisfaction. |
02-02-2015, 09:03 AM | #7 |
Rep 205
Leason learned I guess.
Just wish they would at least inform that its not a perfect fit for the 320i. I've been cutting in both the DP and exhaust pipe to make it fit so the car is drivable again. Did not expect this kind of trouble, now I need to go to a workshop to get a permanent fix done. I also read reviews about the IC that does not fit. I'm so sceptical now that I'm not going to try to install my ER CP. I think it will do better as some sort of christmas decoration.
02-02-2015, 09:35 AM | #8 |
Rep 52
its unfortunate and actually CRAP that op had this much trouble. i'm in the market also for a dp and have to say that I was planning on steering away from er for similar reasons that i've read about numerous times. NOTHING worse than a supposed "bolt on part" that does NOT just bolt on.
02-02-2015, 11:30 AM | #9 |
Rep 205
Workshop ask about 300$ to fix it which is something I will have to think about. They want to take of both DP and exhaust to weld new fittings on both that will fit together.
I'm getting really tired of this shit and decided to give it one last try with some clamps and additional sheets of metal and see if I can get it tight. If not I don't have other option than paying the workshop. Anyone know if it is possible to drive the car to the workshop without DP??? or will the missing sensor signals crash the engine? Thinking about to uninstall the parts myself to keep the price down.
02-02-2015, 11:34 AM | #10 | |
Rep 205
I think if left at a popper workshop they should have what ever special tools to make it fit one way or another.
02-02-2015, 03:34 PM | #11 |
BimmerPost Supporting Vendor
24266
Rep 190,952
As a vendor, i currently do business with more than 80 brands.
Evolution Racewerks is one of the best companies i have ever dealt with !! Amazing products + top notch customer service. ER stand 100% behind their products and if the product is less than 100%, they will gladly fix the issue for you. OP, i recommend you call ER and they will take care of this for you.
02-02-2015, 04:03 PM | #12 |
Rep 863
Hi TomDenmark,
Please give us a call at 626-814-3403 with your issues about the downpipe. We would like to get more of an idea on the fitment issue. We would like to determine if you were sold the wrong downpipe or any errors in regards to the item you have received. You have an lifetime warranty on the unit on all manufacturer's defects and we would love the chance to correct this for you. Just noticed that you are in Brazil. If you can send you phone number to Christine@evolutionracewerks.com she will call you to get this matter cleared up. |
02-02-2015, 06:02 PM | #13 | |
Rep 205
02-02-2015, 08:18 PM | #15 | |
Rep 5,316
Drives: G80 M3 6MT
(but not in the fun, upbeat way the emoticon suggests)
Scott, Partner
02-03-2015, 12:14 PM | #16 | |
Rep 205
Now pictures will not help anything as both pieces have been altered. I will post what final result or conclusion I've got when I finished talking with ER who seems to really want to fix the issue.
02-03-2015, 02:13 PM | #17 |
171
Rep 1,397
isnt the piping for the exhuast different for 320 and 328?
thats what i remember reading somewhere on this forum... someone tried putting a 328 exhaust on and 320 but it wouldnt fit cause the piping was different diameters. |
02-03-2015, 07:54 PM | #18 |
Rep 205
I've been in contact with Evolution Racewerks and I must say that they are very service minded.
They are helping me solve the problem, will post more details when job is completed.
02-04-2015, 05:47 AM | #19 |
Rep 61
02-04-2015, 06:02 AM | #20 | |
e92 - 335i
179
Rep 743
http://www.realoem.com/bmw/showparts...75&hg=18&fg=10 http://www.realoem.com/bmw/showparts...75&hg=18&fg=10 I'm confident ER will do whatever possible to make the OP happy. |
02-04-2015, 07:07 AM | #21 |
Rep 186
I am wondering if OP bought a wrong part for his vehicle.... I have a couple of friends here in Singapore where we are using the ER chargepipe, downpipe and intercooler.. Fitment was never an issue...
02-04-2015, 09:24 AM | #22 |
Rep 205
I bought it from http://n54tuning.com/index.php?_a=vi...&productId=110
Description says: Introducing our new Competition Series 4" Downpipes for your N20 four cylinder turbo engine! Fits all 2012+ 320i, 328i, 420i, 428i with the N20 engine (does not fit N26 engine).
