E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Map update error code
      01-25-2015, 07:57 AM   #1
Fwtd
Drives: E90 3301 Msport
Hi all,
I've been trying on and off to update my professional nav system on my e90 2009 330i lci for some time now, I have been consistently getting an error message stating my code is incorrect. I have bought 2 codes from 2 separate vendors and both are the exact same and therefore produce the same error message. Is this something anyone else has experienced? The nav system is factory fitted aswell.
Thanks
Fwtd
      01-25-2015, 08:26 AM   #2
makkan00
makkan00's Avatar
Drives: F83 and F36
I have encountered same issues on one CIC.
Solution was to update the firmware on CIC and then code works like a charm.
FSC codes is based on latest firmware and I think your CIC is on old firmware with old algorithm and hence error.
If your car is under warranty, ask your dealer to update your CIC.
If its out of warranty, then find local indy who can update your CIC.
or somebody whom you can post it and he can update the firmware on the table.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      01-25-2015, 04:04 PM   #3
Fwtd
Thanks for that,
My car ran out of warranty last week, is there any particular tactic or reason I should give to the dealer for them to update it? I will try and get them to do it as a good will gesture as my warranty has just ran out
e90post
