DS mode vs Manual Transmission
01-23-2015, 05:34 PM | #1 |
Rep 60
I was wondering if the automatics DS mode is as fast as if you had a manual tranny. Also is the manual automatic or DS mode better for 0-60. Cheers!
Instagram: BMWTerritory |
01-23-2015, 05:45 PM | #2 |
Rep 2,202
Manual transmission has the advantage for better rev match so I'd give the plus to the 6peed.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
01-23-2015, 05:45 PM | #3 |
Rep 156
I will acknowledge that the auto in DS mode shifts faster than I can. There, I said it.
And because it shifts faster, accel is quicker as well. |
01-23-2015, 05:49 PM | #4 |
Rep 60
Im so happy to hear that!
01-23-2015, 06:20 PM | #5 |
Rep 3,189
01-23-2015, 06:32 PM | #6 |
GoofBall
50
Rep 1,055
The newer tech autos will have the advantage. Look at the current batch of super cars, almost all of them are DSC or Autos in some way shape or form. The manuals are still needed for the guys who like to "drive" the car. I miss being connected to the car but my wife cant drive one and I don't want to ever put her in a position where she needs to drive my car and cant.
Autos are more consistent and with proper electronics, not that we have them can be a stick shift sloppy and useless. With the ability to set shift points it will never miss, never over rev, never early shift they can be amazing. Not ours though, we get a flash. |
01-23-2015, 06:32 PM | #7 |
Rep 5,627
For a 2008 328i, BMW quoted a better 0~60 time for the manual transmission by about .3 seconds. IIRC, The 335i times were just about identical for Steptronic and MT.
Even for the new turbo 328i, the MT is .1 second faster to 60. http://www.bmwusa.com/Standard/Conte...fications.aspx Tom |
01-23-2015, 07:01 PM | #9 | |
Rep 5,627
And even the current M3 with a 7 peed DCT (no fluid coupling) is only a couple of tenths faster than the 6 speed MT - mainly due to the DCT's much lower 1st and 2nd gear ratios. http://www.bmwusa.com/Standard/Conte...fications.aspx Tom |
01-23-2015, 07:03 PM | #10 |
Rep 2,731
I can honestly say that the BMW auto transmission shifts like no other auto I have ever driven. It has very little lag at all, it shifts nice in regular D mode, and it shifts aggressively when you need it to in DS. It's almost like it can read my mind. It doesn't hesitate.
01-23-2015, 07:07 PM | #11 |
Thats all you need to know.
43
Rep 1,188
DCT
Auto Manual Auto is not very good at down shift points IMO, even in sport. I think a manual will eventually do better in a technical area. Having driven them all DCT is the clear winner overall.
- M2 2018 LBB / Black
- X5 F15 2016 Mineral White / Black 1981 Delorean number 6489 |
01-23-2015, 07:13 PM | #12 |
Rep 2,731
In the DS mode it does do a pretty good job of holding it in a lower gear at higher RPM where the power is. Even when you let off the gas pedal it will hold it in a lower gear instead of just going into granny mode.
01-23-2015, 07:34 PM | #14 |
Rep 311
True the auto can shift faster, but the power losses are greater, probably evening out with a slight advantage to the manual. Been a long day at work, so I'm not gonna do a bunch of math to justify, but just look at the .1,.2,.3 second differences. Not huge and easily within the realm of driver technique when it comes to racing.
I prefer the 6MT in my 335. The 8spd auto in the X1 we have is about a flawless as an auto tranny is going to get. Just depends on the car's personality in my book. Having said all that, I'm looking at getting an M4 in a couple of years, and I am truly on the fence about whether to get the DCT or 6 MT in it. |
01-23-2015, 08:03 PM | #16 |
Rep 335
I would say the auto is faster, but I would not trade my 6MT for a DS. You cannot beat the enjoyment of driving a MT.
01-23-2015, 08:10 PM | #17 |
Rep 2,731
01-23-2015, 08:10 PM | #18 | |
Rep 2,872
I prefer manual, and that's across the board, simply because I like being in direct control of everything, which is the common trait amongst manual transmission drivers. Aside from that, the 6MT on the N54 platform appears to have endless capability (so far) of high HP/TQ as long as there's a good clutch setup in place, so guys looking into ST or hybrids with high power should definitely consider the MT unless they're able to buy into the Level 10 setups, etc. which have proven themselves as well. Regardless, this debate could go on forever, and always has on every platform.
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
01-23-2015, 08:55 PM | #19 | |
Rep 5,627
Tom |
01-23-2015, 09:12 PM | #20 | |
Rep 2,731
Page 010-18 of the bentley manual says this: "The torque converter uses an integrated torsion damper which avoids unnecessary slip and power loss.The converter clutch is closed immediately after the vehicle starts off. In this way, it feels similar to a manual transmission, with short response and shift times." And to back that up, this BMW tech document I am attaching to this post says the same thing.... "Standstill decoupling The standstill decoupling of the torque converter decouples the torque converter from the drive when the vehicle is at a standstill. Thus only a minimum load remains, and fuel consumption is reduced. The decoupling is effected by clutch A within the transmission being regulated (depending on the load signal and output speed)." So Tom, it appears it locks up instantly and stays locked up. No losses from the torque converter my friend |
01-23-2015, 09:56 PM | #21 |
Gateropode
329
Rep 2,848
When you paddle shift, it shifts quicker than a MT, but it does so after a random delay (.2 to up to 1 full second). Very irritating. Whatever the 0-60, I will never get am auto again.
01-23-2015, 10:00 PM | #22 |
Where'd my VTEC go?
481
Rep 6,067
Automatics these days are insanely good. Most of the time the auto will be faster than the manual in new cars these days, especially in turbo cars because they get to maintain boost between shifts.
I would still always go with the stick whenever it's available. The more engaging driving experience is far more important to me than a few tenths of a second on a timed run.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
