2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications M Performance Pedal Installation in S. Florida
      01-13-2015, 02:09 PM   #1
nathy228i
nathy228i's Avatar
Drives: X4
2015 BMW 228i  [0.00]
Hi all,
Any recommendations for a place in South Florida to have the M performance pedals installed? I got a quote for $75 but thought it was a little too much, given that I read in another thread of someone paying $25. I wouldn't risk it and do it myself, so looking for other options.
Thanks in advance,
      01-13-2015, 02:23 PM   #2
DCastaneda
Drives: '17 340i M Sport
Did you already buy the pedals? There are some lookalikes available on eBay that just slide on.
If you definitely want to use the BMW ones, check out Miami Performance Inc on 117 ave and sw 120th st (West Kendall area). Owner and head tech are nice, and seem to know what they're doing.
      01-13-2015, 03:52 PM   #3
nathy228i
nathy228i's Avatar
Drives: X4
Yes, I got them for Christmas...
Thank you! I will try that place out
      01-13-2015, 05:29 PM   #4
tbc417
Drives: 2018 M2
I found them super easy to install, and I never do this stuff myself you might be ok.
      01-17-2015, 03:04 PM   #5
nathy228i
nathy228i's Avatar
Drives: X4
Called a few places and they all charge between $75 and $80 so I asked my bf to install them and it took him about one hour with no previous experience
      02-12-2015, 10:14 AM   #6
Asteele
Drives: M235i
Is there a DIY thread on how to install the pedals?
      02-12-2015, 06:10 PM   #7
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
No, but very easy. On the brake petal (and clutch) first take the rubber stock pedal off. Then line up the new pedal and mark where the holes are. Drill the holes and screw in the new pedals.
On the gas pedal, just line up the new pedal over the stock pedal. Mark the holes and drill. Then screw in the new pedal.
      02-13-2015, 01:01 PM   #8
Asteele
Drives: M235i
Is there a special drill bit that needs to be used?
      02-13-2015, 02:41 PM   #9
Cattivo
FDNY Engine 55
Cattivo's Avatar
Drives: X5M, X5 50i Msport, EscaHoe
I would use a 1'' wood (paddle) bit
      02-13-2015, 03:17 PM   #10
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
I think it's either 3MM or 4.5MM it is definitely not 1".
      02-13-2015, 06:33 PM   #11
DanG
DanG's Avatar
2018 BMW M2  [7.68]
I can't remember the size. Just look at the screws and use one that is close. There are nuts on the back side so it can be a little bit larger than the screws. It has to be a metal bit since both the brake and clutch pedals are metal. The gas pedal is plastic.
      02-14-2015, 02:39 PM   #12
Asteele
Drives: M235i
Appreciate it, putting them on today. Hope it's as easy you described it! Bmw quoted me $75-$90 to install. No thanks.
      02-14-2015, 05:34 PM   #13
DanG
DanG's Avatar
2018 BMW M2  [7.68]
Good luck. Tell us how you did.
Tags
installation, m performance pedals, miami, south florida
2addicts
