Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      01-09-2015, 11:40 AM   #1
Padfan9
Sergeant
Padfan9's Avatar
Drives: 2022 M8 Competition Coupe
KW HAS for M4
I intended to leave my M4 suspension alone since it handles so great already, plus I have the adaptive M suspension (a must have) so I didn't want to mess with it.
I was told the KW HAS springs were best if I want to lower the car. I am keeping my 19" black wheels, but I don't like the fender gap. I was thinking to lower it around .6 and get the suspension. My car is in the shop for a month anyways, so they will put them on for free while they are fixing a few other things.
What do you guys think? Will it be much harsher then stock? How will the car handle around corners vs stock? Any thoughts?
'22 F92 M8 Competition Coupe - Frozen Brilliant White | 8 Speed DCT | Sakhir Orange/Black Full Leather | M Perf CF Exterior Package | M Perf. CF Exhaust | BBS FI-R 21" Wheels |
      01-09-2015, 12:01 PM   #2
Padfan9
Sergeant
Padfan9's Avatar
KW HAS
See below
      01-09-2015, 12:16 PM   #3
tom @ eas
BimmerPost Supporting Vendor
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
You would be fine with springs alone. However, the HAS will allow you to dial in the exact drop you want.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      01-09-2015, 12:47 PM   #4
Padfan9
Sergeant
Padfan9's Avatar
The springs seem cheap and I have heard its a harsh ride.
      01-09-2015, 12:53 PM   #5
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Not true at all. HAS consists of a replacement spring on an adjustable perch. In the end, springs will give a fixed drop vs adjustable height with KW's HAS.
Here's a comparison of OEM, H&R 435 Sports and H&R M3/M4 springs:
Stock
435 H&R Sport Springs
M3/M4 H&R Sport Springs
OEM Spring measurement
435 H&R Sport measurement
M3/M4 H&R Sport Spring Measurement
Front drop is identical. Approximately 1/4" different in rear height between 435 vs M3/M4. HAS will allow similar results, with the added adjustibility as an option.
      01-09-2015, 05:17 PM   #6
Padfan9
Sergeant
Padfan9's Avatar
Stock
So the H&R Springs do the exact same thing as the KW HAS except the KW is adjustable? Do the H&R Springs take every car down the same exact height?
I was just worried about the ride...I have heard from people with H&R that you sacrifice some handling with them vs HAS being better.
      01-09-2015, 07:16 PM   #7
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Both serve different purposes:
- Springs drop to a predetermined height
- Sleeve Kit/HAS allows you to adjust the drop you want with the included adjustment collars
There is a very slight change in handling. Most are happy with the drop springs offer.
      01-10-2015, 10:29 AM   #8
CanAutM3
CanAutM3's Avatar
Drives: 2021 911 turbo
Stock
Thank you for that post. Super great real world info!!!
Wouldn't another benefit of the HAS be the ability to do corner balancing?
Further, how easy is it to change the ride height on the fly with the K&W HAS? The reason for my asking is that my car is a four season DD and I am a bit hesitant going with lowered springs for the reduced ground clearance in the winter. But if it is relatively easy to change ride height with the HAS, that could be an interresting option for me.
      01-10-2015, 01:01 PM   #9
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Good point.
Changing ride height is not too hard of a task if you are the DIY type. Most shops can do this in under an hour.
      01-10-2015, 01:14 PM   #10
kokopuffs405
Yup
kokopuffs405's Avatar
104
Drives: BMW?
2014 BMW M5  [0.00]
Do you lose adaptive suspensive ability with springs?
Oh hello
      01-10-2015, 02:38 PM   #11
CanAutM3
CanAutM3's Avatar
With springs only, the active suspension remains as it is only effective on the shocks.
However, the EDC was calibrated with the stock springs, so it might not be as optimal with aftermarket springs.
      01-13-2015, 11:12 AM   #12
Padfan9
Sergeant
Padfan9's Avatar
Are you saying the KW HAS will not keep the adaptive M suspension in tact or the H&R springs?
      01-13-2015, 11:14 AM   #13
Padfan9
Sergeant
Padfan9's Avatar
Stock
Sorry Tom, I forgot to thank you for all of this information, it was extremely helpful!
      01-13-2015, 11:23 AM   #14
CanAutM3
CanAutM3's Avatar
If you change only the springs, as is the case with the K&W HAS and K&W, EDC remains active.
      01-13-2015, 11:25 AM   #15
Padfan9
Sergeant
Padfan9's Avatar
Perfect, thank you!
Do you think I should go with the H&R spacers or the Macht Schnell? I heard the Macht Schnell have not been tested as extensively so H&R is a safer bet.
      01-13-2015, 11:29 AM   #16
CanAutM3
CanAutM3's Avatar
Perfect, thank you!
Spacer are pretty simple parts, not much risk there. I would say you are safe with either one. You will need longer bolts with spacers, the quality of those is much more critical.
      01-13-2015, 11:32 AM   #17
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Perfect, thank you!
The Macht Schnell spacers have been on the market for a number of years and come with everything needed for installation, most E9X M3s are running them since release. There's a dedicated thread here with plenty of examples of setups to base your decision upon:
F8X M3/M4 Macht Schnell wheel spacer reference thread
http://f80.bimmerpost.com/forums/sho....php?t=1000804
Do note that H&R does not come with extended lugs, you're on your own to source them.
      01-13-2015, 11:36 AM   #18
Padfan9
Sergeant
Padfan9's Avatar
I think they would be from Supreme Power? Black ones. I am not sure if they are brand or not.
      01-13-2015, 11:48 AM   #19
Padfan9
Sergeant
Padfan9's Avatar
Ahh! That does help!
The options I have seen are :
Go with Macht Schnell and their own extended lugs or H&R (save a little) but pay an extra $80 for extended lugs.
I just can't seem to find the spacers on their website for the F8x
      01-13-2015, 01:13 PM   #20
supremepower
Supreme Leader
supremepower's Avatar
Drives: G80, 996GT2, 996TT, 991RS 356b
The H&R spacers are generic. There is no set individually made for the F8x. It's just in the BMW bolt pattern of 5/120 the bolts are not included with H&R though, as said in previous posts
      01-13-2015, 09:46 PM   #21
Buddy Revell
Drives: E92 M3, M4, 991 911 Turbo
Will my Macht Snell spacers and lugs that I used on my E92 work on my F82?
      01-14-2015, 02:37 PM   #22
supremepower
Supreme Leader
Yes, they have the same bolt pattern of 5/120
SupremePOWER
1562 Kimberly Ave Fullerton CA 92831
Contact: sales@supremepower.com :: Shop# (714)632-1951
Sales & service of BBS Street & Motorsport products.
BBS Highest Volume Dealer 2015 thru 2022
All the top brands at the prices and service you can count on. Professional installation.
f80post
