Help needed to identify what this is ?
01-06-2015, 01:13 AM | #1 |
Rep 31
Tried to take engine cover off a couple of days ago and had problems with last cover hex bolt, became clear that the last owner had tried and failed badly , tried grooving the head of the bolt and ended up snapping the cover, noticed that i now have a hole and a small amount of fumes coming from the hole ...is this the rocker cover ?
Is it safe to drive for now , work in Aberdeen and wont get it looked at until Friday possibly |
01-06-2015, 01:26 AM | #2 |
Rep 4,261
Have a look on realoem HERE
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
01-06-2015, 02:11 AM | #5 |
Rep 4,261
Which engine is it 335d ?
01-06-2015, 02:11 AM | #6 |
Rep 4,261
Oh and year ?
01-06-2015, 04:49 AM | #10 |
Rep 5,050
There looks to be a part number on it, try to Google it or put it into RealOEM
edit: or post the number here and someone will be able to help |
01-06-2015, 05:16 AM | #12 |
DIE ANTWOORD
68
Rep 640
Number 11
Leads from breather valve to the hose that's between air filter and turbo intake. http://de.bmwfans.info/parts-catalog...er_head_cover/ Sure you snapped it? It's made from very durable plastic.
King of the road says you move to slow
01-06-2015, 05:43 AM | #13 |
Rep 31
dont think its the actuual pipe though its where the bolt goes through for the acoustic cover , whatever the bolt screws into has cracked .So its kinda at the side of that pipe
01-06-2015, 10:11 AM | #14 |
Rep 55
It look's like the rocker cover to me . It will be designed with the thread's moulded in the cover with the brass fitting's . But if they turn because they are seized with the bolt it can split the plastic . Have a look at where the oil filler cap is the part that screw's into is the rocker cover . If it is the same plastic that the bolt head is in . Then it it the rocker cover . If you are going to change it . Put a new gasket on it also .
01-06-2015, 10:19 AM | #15 |
DIE ANTWOORD
68
Rep 640
You broke out the bolt together with the brass female? You must be strong as Chuck Norris. I'm afraid then you'll need the whole valve cover (Nr.1 in the catalogue) unless you find one who can glue/weld glass fibre reinforced plastic
01-06-2015, 10:24 AM | #16 |
Rep 31
Thanks pal yeh thats what i feared too , been confirmed by BMW its the whole cover , £550 to replace fitted ...no danger .....gonna bond it , not a lot of pressure at the top of the casing anyways i feel
01-06-2015, 10:53 AM | #17 |
DIE ANTWOORD
68
Rep 640
Yes, give it a try. You may use the two bolts from the vacuum tank to provide support.
