E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > 330d breather diameter?
      12-28-2014, 10:26 AM   #1
Dan-danGT
Dan-danGT's Avatar
Drives: E90 330d M-Sport
Evening all I'm considering changing my breather for an external catch can. I Have already changed the bmw breather but would like some extra protection as such! The only pipe I am able to use is just under the MAF sensor. Does anyone know the diameter of the pipe?
I think it's different on both ends, I will be taking it off tomorrow to measure anyway. Does anyone have any advice on breather tank?
      12-28-2014, 02:09 PM   #2
elbutio
Drives: 335d F31 & 330d E91
Is your car the LCI (post 58 plate) 330d??
      12-28-2014, 04:33 PM   #3
Dan-danGT
Dan-danGT's Avatar
Pre lci 08 plate
      01-02-2015, 01:36 AM   #4
Dan-danGT
Dan-danGT's Avatar
I have a question relating to 330d engine. I would like to improve the breather system, now looking at the breather pipe before the turbo I dont have alot of room to put two breather pipes to a catch can.
My question is can I buy a 335d breather which I believe vents at the top of the engine into a pipe? then fit that and run a pipe from the breather to a catch can then to the intake pipe like normal? I know many might have the 335d so this might be a little difficult but hopefully someone might be able to help me.
      01-06-2015, 01:15 PM   #5
ade146
Drives: E90 330d sport auto
I looked at doing something similar but as you have noticed you would probably have to buy two commercially made 90deg bends.
You could try putting a vortex into your empty breather box. It helps, or if you dont mind changing the filters put a filter cartridge in there.
      07-01-2015, 12:44 PM   #6
mayhs
Drives: 2006 BMW E90 330d M-Sport
Sorry to hijack the thread, but just wanted to get a bit of clarification on the empty breather box. I seem to be getting moderate oil consumption but just wondering if its worth putting a vortex breather into the box.
Its quite a bit of work to get to the breather if I remember correctly so just wondering if that would help reduce my oil consumption and if so, howcome BMW didn't put either a filter or vortex in the original design?
      07-01-2015, 02:47 PM   #7
ade146
They have had several iterations of this breather. On the E46 they had the same box with a loo roll filter. They didnt have them on the service interval and some blocked causing excess pressure.
On the E90 they didnt put anything in the box.
On the 5 series they put a vortex thingy in there.
So BMW have never been able to make up their minds on this.
They issued a PUMA for customers with high oil consumption to fit a loo roll filter in the empty box but only on complaint. The diaphragm and spring do not operate in any of the above as far as I know. BMW probably stole the part from a heinkel or something and thats why they have the vac nipple which isnt used.
e90post
