Autotalent
Go Back   BMW M3 and BMW M4 Forum > Classifieds > Sponsors Classifieds > Suspension / Brakes / Chassis / Spacers
      12-19-2014, 10:02 AM   #1
IND-Distribution
BimmerPost Supporting Vendor
IND-Distribution's Avatar
Drives: G80 M3 / G82 M4
IND | Fall Line Motorsports F8X M3/M4 Toe Link Kit
A byproduct of multi-link suspension arrangements is a dynamic change in the car’s alignment settings- when making an adjustment to one attribute, such as camber, track width and toe will follow. This is especially true for the F8x vehicles, as the original BMW camber eccentric bolt has a major impact on toe as well. Alignments are made faster and simpler when using a set of aftermarket lower arms, enabling the alignment tech to easily reset toe after adjusting camber.
The Fall Line Motorsports F8X M3/M4 Toe Link Kit is designed to facilitate rapid adjustments of toe during an alignment, and combined with the tension strut will also enable adjustment of overall track. Not only does this allow for fine tuning of wheel fitment, these arms will allow an alignment shop to make quick work of car setup, even simplifying the camber adjustment process as a result.
The Race version of the toe link kit utilizes a unique clamp-style fastener system as seen in BMW’s own tie rods and Porsche Motorsport components, tightening the adjustment arm in place with no stretch of the hardware or change of alignment. Less expensive jam-nut designs limit precision and nearly guarantee an alignment change when the jam-nut is tightened. As will all Fall Line suspension components, high quality Aurora bearings are used to ensure a very long service life. ARP hardware is used throughout to guarantee the highest level of durability. Laser cut lockout washers correctly eliminate the original BMW adjustment, eliminating any unwanted movement in the system.
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
The Fall Line Motorsports F8X M3/M4 Toe Link Kits may be viewed here in our online store:
https://ind-distribution.com/product...M-F8X-1FECOTOE
Street Version:
Race Version:
IND DISTRIBUTION | 866-963-4520 • INSTAGRAM • YOUTUBE • FACEBOOK • FLICKR
      06-05-2015, 03:58 PM   #2
IND-Distribution
Standard and Race toe link kits are in stock at IND
      08-19-2015, 01:09 AM   #3
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
I just installed the Street Rear Toe link kit on my F82 M4.
What a great piece of hardware! Everything I would ever want from a solid bushing replacement - no noise, much easier alignment, dust boots, and cheap for what you get! Installs easily and the alignment techs love them.
There is a noticeable improvement in stability once you have the rear end really out of shape, it's much more predictable without that squishy loading up that the stock suspension does.
DSC_3369 by Kit W, on Flickr
Remonster821.00
      08-19-2015, 12:04 PM   #4
IND-Distribution
Thank you for the feedback!
      08-21-2015, 08:00 AM   #5
mshab356
Go ///M or go home
mshab356's Avatar
Drives: 2015 F80 M3 6MT
Damn that race kit must be something serious if it is 4 times more expensive than the street!
Looks like some good stuff!
2015 AB/SO F80 M3 6MT | 19" Black M437 | KW H.A.S. | AutoTechnik Black Front Grills | BMW Performance Side Grills | Painted Front Bumper Reflectors | Gloss Black Exhaust Tips
GONE 2011 SG/Blk E92 M3 CS 6MT
      08-21-2015, 10:50 AM   #6
IND-Distribution
Thanks!
The race kit is a more technically elegant solution, but the standard kit works well also. The race toe arms have machined ends that allow for a clamp style adjustment lock, and a Kephos coating used in F1 suspension arms. The machining operations and the higher end coating are what create the higher cost.
      08-21-2015, 03:04 PM   #7
mshab356
Go ///M or go home
mshab356's Avatar
Thanks!
That's great info! Yeah I figured as much. Seems to be worth the extra cost, it just was a big difference which is what caught my attention. Definitely not needed for me until I decide to really track my car a lot more. Either way good luck with selling these. I'm sure you have lots of satisfied clients
      08-22-2015, 02:58 PM   #8
kitw
kitw's Avatar
471
Personally, I'm really happy with the toe arms on the street. They really do firm up the back end of the car, such that you have more control, especially with the tires spinning - these cars generate a huge amount of torque and I got a ton of back end squishiness when the tires were spinning. It's a much cleaner action now, with more predictability.
      08-23-2015, 12:34 AM   #9
mshab356
Go ///M or go home
mshab356's Avatar
So it's worth the $250? Should I pair it with aftermarket suspension or is it good with stock suspension?
      08-27-2015, 12:52 AM   #10
kitw
kitw's Avatar
471
Either! works great with stock to keep the rear end more predictable.
      09-30-2015, 02:37 PM   #11
Nate@IND
Nate@IND's Avatar
2863
Both Fall-line toe link kits in stock at IND.
http://ind-distribution.com/ind/bran...4-toe-link-kit
Thanks for the feedback!
IND DISTRIBUTION | 866-963-4520 • FACEBOOK • INSTAGRAM • FLICKR
      11-02-2015, 02:11 PM   #12
330cibimmer
330cibimmer's Avatar
398
Drives: 2016 BMW M4 ZCP
Sent you guys a pm. Please check your inbox.
Thanks
      11-03-2015, 01:40 PM   #13
IND-Distribution
Thanks
PM sent!
      11-04-2015, 05:10 PM   #14
330cibimmer
398
How big of a difference does this make as far as cornering stability? I plan to put on swift lowering springs and wondering if this is a necessary upgrade or will I be just fine with just the springs?
Plan to track the car maybe once a year
Thanks for any input
      11-05-2015, 12:52 PM   #15
330cibimmer
398
No one?
      11-05-2015, 01:18 PM   #16
te37
te37's Avatar
545
Drives: F80 SS/SO 6MT
These are SEXY... that ARP hardware
      11-10-2015, 03:50 PM   #17
IND-Distribution
The toe arms will help to easily and properly set toe - aiding in achieving a properly set alignment and thus improving performance on track.
The original BMW arm that these toe links replace has a bushing inside that moves during cornering. Removing compliant bushings will assist in creating a better handling car, but doing so one component at a time will have a relatively minor impact - especially if the car only has lowering springs installed for roll stiffness.
      11-28-2015, 08:13 PM   #18
TahoeM3
Drives: F-type R, GTR, X5 50i
Do these toe links stabilize the rear wheels under hard acceleration as the Dinan ones claim to do? Does this help keep the tires in contact with the pavement and improve acceleration off the line?
2017 F-type SVR Black/black
2017 Nissan GTR Red/black
2022 BMW X5M MBB/SO
Gone but not forgotten: '12 X5M, '07 AM SuperVantage, '05 Boxster S, '01 BMW M3,...
      12-18-2015, 03:48 PM   #19
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
These toe links will stabilize the rear in all conditions of heavy load by removing the original rubber bushing, and replacing it with a rigid spherical bearing. Removing that compliant bushing will limit geometry change, maintain a more consistent toe, and keep the car stable as loads are applied to the rear wheels.
The ability to freely adjust toe will also improve acceleration off the line, by allowing you to obtain a more favorable toe setting.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAM • FACEBOOK • FLICKR
      05-26-2016, 07:21 PM   #20
04RC51
Large Member
04RC51's Avatar
951
Drives: E92 M3, F82 M4
Originally Posted by Ryan@IND View Post
IND's 2016 Memorial Day Sale is now live!
Enter promo code "memorial16" upon checkout on our website: http://ind-distribution.com/ind/
F32 N55
2008 E92 M3 (Engine swap completed), 2015 F82 M4
      05-27-2016, 06:56 AM   #21
G30 B58
Pace Car Driver
1547
Drives: '22 AW G30 B58 M-Sport
Originally Posted by 04RC51 View Post
F32 N55
I think you should call @Cat@IND and see what's up.
      09-06-2016, 06:58 AM   #22
m4282
Drives: Tanzanite Blue M4 w/Leather
Images below are of the Race kit:
Fall Line Motorsports F8X M3/M4 Toe Link Kit: $258 // Race kit $1029
Hi cat - what's the difference between these (race version) rear toe links and the one offered by Dinan?
Dinan replaces all 4 rear links but I only see two links here being offered for the rear , is this correct?
Also regarding the standard version and the race version of these fall rear toe links - what's the difference in durability?
And what's the difference in durability vs those of the stock ones currently on the f82 non zcp? Thx
f80post
