12-06-2014, 08:16 PM | #1 |
Rep 556
Suction hose need some help.
Thank you for the DIY for the plenum that was crucial and so helpful.
I am currently stuck trying to get the suction hose off the part that sits at the far end of the throttle bodies. (listed as part number 10 in this thread: http://www.m3post.com/forums/showthread.php?t=710880). I don't want to break any plastic parts just looking for something I might be missing out as I am a total novice. Thanks |
12-06-2014, 08:24 PM | #2 |
Rep 10,614
Depress on the sides of the clip and gently wiggle/pull. Could be stuck. Try spraying some silicone lube and maybe it will work its way in.
12-06-2014, 08:30 PM | #3 |
Rep 556
Problem is I can't get my hand in that tight space. I tried to unbolt the brace and the 2 TORX 30 bolts but the part doesn't budge. I was hoping to get some more wiggle room.
Would WD40 work? |
